holly electric choke question
Discussion in 'The Hokey Ass Message Board' started by ykp53, Sep 28, 2010.
  1. ykp53
    ykp53
    from macon ga
    can you get the power supply for the electric choke from the positive terminal on the coil. is this a safe place to draw from?
    this is on a 62 impala with a 327
  2. moparted
    moparted
    from upstate ny
    if its 12volts there.
  3. merf
    merf
    from new joisey
    Key on power from the fuse block would be better. The choke gets hot because it's a controlled short circuit. You don't need a voltage drop at the coil. Most times it works ok but I've had no starts if the battery's low or the starter draws a lot.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No because that sourse is resistored.
