Home made intake????
Discussion in 'The Hokey Ass Message Board' started by lukey, Apr 24, 2012.
  1. Phil1934
    Phil1934
    I mounted four Pinto carbs on a SBC B&M blower intake by welding a plate on the opening and four high rise 32/36 to 1 bbl adapters which have an upper and lower flange over the runners and bored through. This could be done with other intakes, say a 4 bbl. No milling and no drilling and tapping for carb bolts.
  2. 73RR
    73RR
  3. jbtine
    jbtine
    I made my intake for a 341 Desoto hemi. Buy the precut intake plates and 4 mandrel u bends. I put a divider between sides. I used the article I'm posting. The worse thing about this setup is the 3 deuces. If the rpm is not high enough when you punch it the engine will bog. If it is in the right range...Hang on. Either va***n secondary front and rear carbs or a single 4 bbl would help.
  4. roseville carl
    roseville carl
    These are homemade...........
  5. plym_46
    plym_46
    from central NY
    contact forum member moose he has made wuite a few for mopar flatheads both ins and outs. I believe his website is down, but a PM ought to get you some information.
  6. Deuces
    Deuces
    I've got a **** load of pictures I took of this car at the Woodward Cruise a couple of years ago.. Let me know if you want me to post those... ;)
  7. Rusty O'Toole
    Rusty O'Toole
    Lots of manifolds have been made of steel plate and exhaust tubes, mainly for race cars and hot rods. They do not have heat as a rule, and were usually made because they wanted LOTS of carbs and nobody made a manifold to hold that many carbs.
    They worked well and set records. No reason you can't make your own manifold but it helps if you know something about how a motor works and don't get carried away.
  8. Shaggy
    Shaggy
    from Sultan, WA
    I havent seen that either!!
  9. PLEASE POST THEM! This car led to several changes in NHRA rules- the max height from ground to crank centerline for one.
  10. I use 18 gauge for the valley pan cover and 1/4-3/8" for the flanges. I build the plenum out of 18 gauge as well, with 3/8" carb pads welded on the top. Unless I build a removable top in which case I bould the entire top out of 3/8 aluminum tapped for the bolt holes and bolt it from the bottom.
    I have been known to cross my runners inside the plenum to get more runner length with less height. When I am being real fancy I start my runner our big and taper them toward the head. But I am not sure how necessary that is on one that is not being scientifically engineered.
