home made tools
Discussion in 'The Hokey Ass Message Board' started by onlychevrolets, Sep 25, 2009.
  1. onlychevrolets
    onlychevrolets
    what I'm looking for is someone's idea of a homemade tool for removing U-joints without beating the **** out of it. Beating them always causes the bearing to fall over and get mashed. Also if you have any cool home made tools post them ....
  2. Mark H
    Mark H
    from Scotland
    You need two sockets,one larger i/d than the bearing cup and one slightly smaller o/d than the bearing cup.
    You also need one bench vise.
    Place the sockets on opposite sides of the u/j,(small one against one bearing cup and the larger one over the opposite bearing cup) and into the vise.As you tighten the vise,the small socket pushes its bearing cap in and the opposite one out.
    Don't forget to remove any circlips or peening.
    Sorry,no pics,but pretty straight forward.Hope this helps.
  3. I use the vice and sockets and it works great.
  4. Old61
    Old61
    from PA
    ^ agreed. When re***embling, pull the caps- put a finger on the end of the bearings and twist the cap. This ****s them slightly and helps keep them in place.
  5. RodStRace
    RodStRace
    Don't forget the bench and a couple 2X4s to keep things fairly level.
    I've seen a lot of mechanics and tools, this works the best. Oh, and a BFH used sparingly is better than a small hammer swung hard....
  6. THE_DUDE
    THE_DUDE
    Most autoparts stores rent a kit that you dont' need a vise.
  7. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    BFH always worked for me. I only use the hot knive to melt out the plastic **** that GM uses. Here's some of my home made tools:
    Engine Yanker
    9" narrowing jig
    Telescoping thingamajig for mocking up rearend to find width to narrow 9"
    Doohicky to hold a rear axle and stuff like that on an engine stand
    Engine test stand
    SBC valve spring compressor
    Cam bearing driver
  8. onlychevrolets
    onlychevrolets
    Now thats what I was after LOBUCROD...I built a flat plate on my engine hoist with a lever to keep it level while raising it, this way I can pull transmissions on my two post lift and all it cost was a couple hours work. Don'y have any pix of it.
  9. grits
    grits
    I made this little jewel to reverse the spring eyes on the front of my coupe, I saw it here on the board and copied it so I can't take credit for the disign but it works great.
  10. BullyDog
    BullyDog
    from Atlanta GA
    grits , cool...I need to build one of those, and onlychevrolets take some pictures of your transmission jack thing I need something like that.
  11. onlychevrolets
    onlychevrolets
    I'll try and get some and post them soon.
  12. aceuh
    aceuh
    A guy on a truck forum I frequent came up with a one man cab/bed lift that works like a champ. It's laid out to be used with a cherry picker...but tractors work as well.
    Technically it's homemade.
  13. bobo
    bobo
    from New Jersey
    Anybody have ideas for lifting a body off it's frame? Need to take the 35 Coupe off of it's frame.
  14. RichG
    RichG
    I've lifted a truck cab before by jacking and blocking the corners until high enough, then using beams to secure the body underneath. You could reduce the overall height necessary by removing the wheels and putting the car on skates (square plate steel with four casters) under each wheel. That horribly place Harbor Freight sells casters super cheap, and the skates can be used for just about anything. Get fancy and put a locking caster on each skate if you want:D
