Hot Rods Home made valve covers
Discussion in 'The Hokey Ass Message Board' started by B.A.KING, Jan 24, 2021.
  1. B.A.KING
    B.A.KING
    Just thinking about trying to do something different with SBC covers. Not just go out and buy something? Any of you guys modified your valve covers? And i don't mean paint between the fins. I guess breathers would be ok if they are truly off the wall. Just wondering with to much time on my hands.
  2. I like the look of the olds rocket valve cover meshed with the sbc valve cover :D
  3. 30dodge
    30dodge
    from Pahrump nv
    I like the idea of disguising the small block Chevy engines. Wild in a "Wild Cat" logo and paint it Blue.
  4. carolina chevrolet
    carolina chevrolet
    What about a clear see through set of valve covers. I saw a set somewhere, not even sure if they were designed to be on a working engine or not.
  5. carolina chevrolet
    carolina chevrolet
    It appears that Cl***ic Industries sells a set of clear covers designed to be used on a SBC. I kinda like those.
    jimmy six and VANDENPLAS like this.
  6. Doublepumper
    Doublepumper
    from OR-WA, USA
    I always wondered why there wasn't a set of covers made with longer fins or more fins to enable better heat dissipation. Something made more like a heat sink.
    VANDENPLAS likes this.
  7. Okay, not "homemade" but "off the wall"........
    (I like the breather in the middle idea on SBC v/c, too. It looks more 'hot roddy".)
    It's a good thing that they made the fins mirror opposites to balance........
    so the wind doesn't spin you around if you go too fast. :eek:
  8. DDDenny
    Reinventing the wheel are ya!
  9. Bandit Billy
    Bandit Billy
    I think welding in or stamping a name in the covers is a cool idea on the right vehicle. One of the guys on here made "PLYMOUTH" hemi valve covers that were righteous! On a 57 Chevy, a cover that had a script "Bel Air" stamped in it would be pretty cool. Or if you had a fake blower and blocked off carbs they could say "POSER" in block letters. Gold "Crown Royal" embossed valve covers on a purple SBC? Tasty! Is it after 12:00?
    fauj, loudbang, Max Gearhead and 2 others like this.
  10. dana barlow
    dana barlow
    from Miami Fla.
    Made some fins on stock tin covers with 4 "U" channels welded to top;looked like 8 fins.
    But later got some real alum Thunderbird covers.
    One guy in our old car club had a OHV 6 cyl,he put 6 draw pulls on top,after painting,looked like vents.
    They were this type.
    https://www.homedepot.com/p/Hickory...r-Stainless-Steel-Cup-Pull-P3055-SS/100674665
    I've seen a few that look good,with a chrome name off of a fender added to top of covers.
    Lil32, loudbang and ekimneirbo like this.
  11. Rusty O'Toole
    Rusty O'Toole
    I got a lot of flak for suggesting you could build up any shape you want in fibregl*** and bondo and paint it, embed aluminum fins or an emblem or what you like. I still don't see why it wouldn't work.
  12. harpo1313
    harpo1313
    from wareham,ma
    Ive always wanted to take, say an Edlebrook or M/T and mill all the tops off and polish away.
  13. goldmountain
    goldmountain
    Here is the ultimate valve cover fake out. Small block Chev. IMG_1304.JPG IMG_1304.JPG
  14. blowby
    blowby
    from Nicasio Ca
    Take a steel valve cover, turn it over and beat it with a ball peen hammer. Weld a piece of an old pushrod sticking through. Install and think up a good story.
  15. nochop
    nochop
    from norcal
    How do I get that vomit taste outta my mouth now?
  16. DDDenny
    catdad49, tractorguy and Deuces like this.
  17. B.A.KING
    B.A.KING
    Yeah I have seen the Canadian "Pontiac covers". Saw them in here. Like i said, rainy Sunday . Just trying to keep my mind off this damn Virus.
    Deuces and VANDENPLAS like this.
  18. Marty Strode
    Marty Strode
    I have been thinking about mounting some Chevy tin covers on a 324 Olds I am building.
  19. nochop
    nochop
    from norcal
    That would be......different, traditional
  20. Jibs
    Jibs
    I had a set of finned aluminum cover that had "Powered By Ford", on a Chevy 350 in my 37 Ford coupe, made a lot of people do a double take, also pissed off some people.
    Deuces, Hnstray, jimmy six and 2 others like this.
  21. ekimneirbo
    ekimneirbo
    Myself, I have never cared for most disguised engines. The more knowledgeable builders can usually tell it's a fake and the others usually don't know what they are looking at anyway. I do think it's fine to try to create a nostalgic look on a newer motor. In that vein I plan to adapt some early style sixties Cad valve covers to a 500 Cad just because I like the square ends better than the rounded ends........but it's still a Cad. Not trying to pi** anyone off, just that most of the time they just don't look right to me:oops:
  22. A friend has a Jaguar V12 ( home built intake with 2x4s a****st other mods)in his T roadster and stuck some small blue oval badges on the cam covers, gets a lot of head scratching going on when the yarn comes out about Fords development engine.
  23. 30 years ago Speedway sold a "kit" that was a pair of adaptors that fit over SBC heads so you could run Hemi valve covers.It was pricy too.
  24. Fordors
    Fordors
    What was it that P.T.Barnum said?
  25. 57JoeFoMoPar
    57JoeFoMoPar
    I think the biggest issue with making a set of valve covers would be machining the flanges. It is a gasket sealing surface after all, so you'd need to get the surface true otherwise your experiment is a failure. As far as "doing something different", what else is there to do? The covers close the top of the engine up and add no performance benefit. . Trying to disguise the engine as another kind of engine is lame. Outside of that, you'd be reinventing the wheel with no appreciable improvement in performance, and depending on level of craftsmanship, no improvement in style either.
    Truckedup, Deuces, loudbang and 5 others like this.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    Well said.
    Deuces and ekimneirbo like this.
  27. warhorseracing
    warhorseracing
    from cameron wv
    I can see it now. Someone cutting out the top of a Ford valve cover and welding it in to the top of a chevy one.:confused: Just so they don't have to listen to me.:rolleyes: Well it won't work.:eek: I know the difference between that and a Y Block.;)
    Deuces, loudbang, clem and 1 other person like this.
  28. COCONUTS
    COCONUTS
    I don't know about this. I have seen several guys who were great welders and metal fabricators just try to add metal to make a deeper oil pan, and they all leak sooner or later.
    Deuces and warhorseracing like this.
  29. 56don
    56don
    You could buy some of those cheap plain unmarked valve covers and take them to one of those hydrographics places and have them coated in just about any design you can imagine.
    Deuces likes this.
  30. ekimneirbo
    ekimneirbo
    I think creating a valve cover that appears to coincide with the motor but might look like some rare original would look much better. A cast aluminum Chevy cover with Jenkins or Yunick emblazoned on top, A Ford with Holman/Moody, Nicholson, Glidden or a Hemi with Garlits on it..............Now that would look good and still start a lot of conversations;)
