Home Made Wide Whites!!!
Discussion in 'The Hokey Ass Message Board' started by low49bowtie, Apr 25, 2008.
  1. low49bowtie
    low49bowtie
    Well i tried the wide white trick with the 36 grit grinder and well it works pretty good.I went and bought me some old used tires to practice on.
    Here are some pics.
    before
    during
    after
  2. BadLuck
    BadLuck
    looks pretty good!...I tried it a few weeks ago, and lets just say they didnt turn out that good! mine were real wavy.....just have to practice more....:)
  3. low49bowtie
    low49bowtie
    Well mine have some waves but im saving some major bucks doing it this way verses buying wide whites from coker which are like 160 ea.In my opinion thats just stupid high!!!Im not cheap im just broke.:rolleyes:
  4. AL'S 50
    AL'S 50
    from RENO,Nev.
    We have a guy here in town that has a machine that turns them down. $20.00 a tire is going rate. I get them done for $10.00 because I do so many! AL:)
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im with you on the coker cost..they are nice and i would love to support a HAMB vendor and all..but 788 bucks to get a set for my Chevy is like taking food out of my kids mouth right now..so im all over this making your own WWW rock on some more info..anyone doing this up here in the Killer city of Detroit or Toledo area?
  6. Lazer5000
    Lazer5000
    I painted mine. Two coats f "KILLZ" and three coats of exterior latex. Working pretty good so far. Where the white insert in the tire is they stay very white, the rest has to be touched up about every six months.
  7. Jay71
    Jay71
    I always wondered if grinding the side wall would jeopardize the integrity of it? I know its just a thin layer taken off, and Ive never heard any horror stories, but.... Tire looks damn good though, and definately an alternative to the big $$$.
  8. K204DR
    K204DR
    from Chatt TN
    I wonder if you put the rear on jackstands, and had it turn slowly while you ground on it if it'd turn out pretty smooth? might need someone in the car to stop things if it got outta control though.
  9. custom50
    custom50
    from Indiana
    I'll have try that on my 50 ford it has the narrow white wall on the rear. I've heard of this but never seen it. Thanks for the picture, looks good.
  10. Autojunkie
    Autojunkie
    Check this place out:
    http://www.myspace.com/widewhites
    He says he makes any tire into a white wall through the process of "cold vulcanizing". I tried finding out what "cold vulcanizing" is, but couldn't find anything on it. I'm curious is anyone has ever heard of it or tried this?
  11. Adam D.
    Adam D.
    150 for all 4 tires?? im down! is this guy from the FoMoCoMoFos? the club is numah uno on his myspace.
  12. flathead48
    flathead48
    I recently shaved a set down for a guy, turned out pretty good. Just takes practice. Your supposed to be careful and not take off more than needed, so shouldn't hurt the integrity of the tire. I like this method better than porta-walls, they ****
  13. MercMan1951
    MercMan1951
  14. junkcad
    junkcad
    from nashville
    im workin 2 for the front of my car now, my little 10 gallon air compressor is struggling !
  15. GREASEMONKEY72
    GREASEMONKEY72
    i sanded my tires down with a flexdisc grinding wheel and then smoothed them out a bit with a metal buffing pad on the grinder, not perfectly flat but i dont care and theyve been there for almost a year now with now probs and mines a daily driver
  16. low49bowtie
    low49bowtie
    This is where i learned it from.
    <object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/xkcm3rh60p0&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/xkcm3rh60p0&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
  17. slick39
    slick39
    from dallas ,ga
    cool thanks for the info
  18. brewsir
    brewsir
    cold vulcanizing.....sounds like a good coat of cantact adhesive to me! (rubber cement and portawalls)
  19. -Brent-
    -Brent-
    Brewsir beat me to it...
    Anyway, here's a link to the definition of vulcanizing. He's not using high heat (like tire factories) so it's got to be a chemical bond through some type of adhesive. His work looks cool in pictures, none-the-less.
  20. cosmo53
    cosmo53
    I'd beware of this guy, i've seen enough bad stuff written about him on here to make me want to look elsewhere.
  21. Maricopa
    Maricopa
  22. Remely54
    Remely54
    What is youre opinion on porta walls? i thought about that at one point till I saw the option grinding it down.
  23. lostn51
    lostn51
    from Tennessee
    one time years ago i almost considered buying a set of port-a-walls and after mounting them getting some gorilla snot and gluing them down. instead i called coker and had a set of firestones shipped to me. but that cold vulcanizing sounds like thats what they are doing. i think i might see if there is anyone around here that cuts the whitewalls and get a set of radials done. the only time i run them is in the winter because they are more snow/ice friendly.
