Homemade bead roller
Discussion in 'The Hokey Ass Message Board' started by DavidP, Mar 27, 2010.
  1. DavidP
    DavidP
    So I don't highjack another thread, something a little different for making custom beads on your floor ...
    Here is an example from one of the micro car websites ...
    The pattern is made using a router on MDF cutting a 1/2" round channel in the pattern your looking to create ... using a hardwood block to tap the 20 gauge metal down into the pattern ...
    Amazing results ... it might be hard to match some of these with a traditional bead roller, especially the interlocking curves & circles ... :rolleyes:
  2. big creep
    big creep
    a lot of work for beads but it sure looks cool!
  3. DavidP
    DavidP
    Another floor being made using 20 gauge sheet metal ... with a plywood pattern ... forming the bead work for the floor on a small Isetta ...
    I'll be trying it myself ... soon ... as I finally found the Isetta that I've been looking for ... :cool:
    I think I got a great deal on it ... it was even sandblasted and delivered ... but I KNEW that I would have to do the floors ... the body is pretty GOOD ... :cool:
      181.4 KB
      217.5 KB
      230.9 KB
      174.6 KB
      55.4 KB
      222.5 KB
  4. zzford
    zzford
    Isettas are COOL !!! Are you going with Allison power?
  5. 0rg0
    0rg0
    Has anyone ever heard of guys using sockets to make beads ?
  6. DavidP
    DavidP
    Since an Isetta came with a single cylinder 13 HP motor to move its almost 800 pounds around origionally ... anything I do with be an improvement ...
    All I NEED is a shoe horn to get my fat *** into it ... :rolleyes:
    http://www.youtube.com/watch?v=Af9UKStjoKU
    There will be limits on how much HP this little car can handle !!!
  7. OHEKK
    OHEKK
    Here's my Isetta... it needs your floor!
  8. ken1939
    ken1939
    Those are neat tips. The second with the larger sheet is something I thought about trying if I had to make a quarter panel for a 32 that needed a belt moulding in the metal.
    There was another post on the Hamb that a guy used a similar method, but made the female part of the pattern in plywood, and used a bead roller die on his moveable machine table. He put the die in the chuck of the drill on the machine table, then attached the plywood and metal to the table. He used the cranks to move the table over the metal creating beads. The problem was making some longer than the throat of the bead roller.
    Use your brain, its allowable!
  9. davis574ord
    davis574ord
    That looks really cool and inexpensive to make thanx for the idea!
  10. daliant
    daliant
    Cool!! thanks for sharing that tip.
  11. Okie Pete
    Okie Pete
    Thanks for sharing.
  12. knotheads
    knotheads
    when i was in high school ,one of my friends put a turbo charged corvair engine and corvair transaxle in a 1957 izetta.
  13. DavidP
    DavidP
    If anyone wants to look at a few more of the restoration pictures related to the origional floor replacement pictures ...
    The site by Whirlibird ... the artist that uses the MDF in the first set of pictures ... http://www.flickr.com/photos/14287541@N04/
    The site by Isetta Bob ... the one using plywood for floor replacement ... http://www.isettabob.com/Restoration/Gallery.aspx?Section=Body
    For those looking for a little more HORSEPOWER ... http://www.europeancarweb.com/features/epcp_1003_1957_bmw_isetta_300/index.html
    I'm not planning anything that will do 0 - 62 mph in 3.5 seconds!!!!!
    Performance
    Peak Power: 150 hp @ 9000 rpm
    Peak Torque: 70 lb-ft @ 7000 rpm
    0-62 mph: 3.5 sec. (est.)
    Top Speed: 150 mph (balls limited)
  14. fitzee
    fitzee
    That is some cool tech. This would work great for doing logos in metal.
  15. OHEKK
    OHEKK
    Like this:
  16. dentisaurus
    dentisaurus
    from Boston
  17. Mister Nasty
    Mister Nasty
    Makes me glad I look in the older posts...Great tip !!!
