Technical Homemade Friction Shocks?
Discussion in 'Traditional Hot Rods' started by ccain, Dec 21, 2022.
  1. ccain
    ccain
    I'm putting together information and gathering parts for my "built from garbage" '29 RPU banger build. I've read through a few threads here, but they (unless I just haven't found the right thread yet) still leave me with a few questions.
    One of the things I'm going to have to consider (like you should) is dampening the front suspension. As you probably well know (unlike the rear and because of the way I'm building this wreck), I'm not going to have much room for hydraulic shocks up front. Besides, they're not going to fit the aesthetic I'm going for.
    Don't get me wrong, I'm not too much of a "form over function" guy, but... I've seen a lot of builds utilizing friction shocks up front. One book I have on building t-buckets (not what I'm building but the frame I built is made partially from t-bucket frame plans.) has a schematic for fabricating friction shocks that, to be honest, looks a little too easy. Basically an arm, a spring, and some leather discs, bolted right to the front of the frame with a torque setting around 20 foot pounds.
    I mean, I understand the concept and the mechanics behind them, I just thought they'd be a little more involved than just a few chunks of metal and some dead cow skin. :confused:
    So, I guess my questions are:
    • Are they really this easy?
    • Do they halfway work?
    • Am I stupid for wanting to use them, period?
    • Have you built any?
    • Can you post up some pics of your homespun friction shocks?
    Hope you guys are having a great day! If my ex-wife is reading this, I hope you have the day you deserve. :p
    Thanks for entertaining my stupidity. :p
    harpo1313 likes this.
  2. brading
    brading
    Here is an idea.
    Tman and ccain like this.
  3. 51504bat
    51504bat
    2 thoughts. 1, there was a thread here from a guy in Brazil who built a speedster with a V-12 IIRC. He built his own friction shocks. Or 2, rear shocks from an MGB is another option. I've seen them on t buckets but sorry no photos.
    ccain likes this.
  4. Bearing Burner
    Bearing Burner
    from W. MA
    I built 2 for the front of out lakester. 4" dia steel disk welded to frame. Friction laminated to it. another 4"disk with arm to front axel. bolt running through both disk welded to back of first disk. Bolt also has key milled in it to allow another 4" steel disk with friction material laminated to it to form a sandwich
    of friction material arm to front axel and another friction surface. I used a beville washer and nylock
    nut to secure it. Takes a little trial and error to determine how much pressure to apply. I got friction
    material from McMaster Carr.
    ccain likes this.
  5. loudbang
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Lots of stock model A s running around with no dampers whatsoever. There is some friction damping in the leaf spring its self and they seem to get removed due to replacement costs.
    Not ideal imho but it seems to work.
    ccain likes this.
  7. Lättähattu
    Lättähattu
    from Finland
    This is how i made mine. Fits to the model A speedsters (stock body with lowered rear end might need modifications). Simply: arm, frame part, pressure plate, friction discs , disc springs and castle nut. Haven't got my speedster on the road yet, but some guys who bought a set said they works pretty well.
    If you do not want to make your own, you can order one of mine from Mike's
    https://www.mikes-afordable.com/product/A18015F.html
  8. 51504bat
    51504bat
  9. ccain
    ccain
    You guys, as always, never disappoint. :cool::cool::cool:
    This is good some **** right here! Feelin' better about 'em with every post. ;)
  10. Yes
    Yes
    No
    Yes
    Nope, busy building...
    ccain likes this.
  11. Mr48chev
    I had a friend with a T bucket that I would see at rod trots in Texas in the 70's who had built a setup pretty similar to what Lattahattu showed in post 7. He would tell me about the different materials he had tried as friction material. Last I knew he said that Masonite disks seemed to work pretty well.
    I had MG Midget lever action shocks on my T bucket and have to think that they were pretty well worn out when I scrounged them at a wrecking yard.
    The shock looked like this one but having just looked up new or rebult ones the cost is pretty stiff running about 500 for a pair of new ones.
    The good thing about them when I had them was how easy they were to install on the T bucket.
    ccain likes this.
  12. woodiewagon46
    woodiewagon46
    from New York
    There is a company called Hartford Friction Shocks, www.packardtwelve.com, they might have the parts you need.
    ccain likes this.
  13. jimmy six
    jimmy six
    Friction shocks are great for a LSR vehicle with very limited axle movement.
    Why do you ask? Because the rules state a sprung wheel requires a shock absorber. Mine meet the rule.
    Tman likes this.
  14. seb fontana
    seb fontana
    from ct
    Friction shocks do work but have to remember that they have a break away torque that diminishes some once they are moving.
  15. denis4x4
    denis4x4
    from Colorado
    Switched from friction shocks to MG Midget/AH Sprite rear shocks and never looked back
    gimpyshotrods, jimmy six and ccain like this.
  16. Dan Timberlake
    Dan Timberlake
  17. Ziggster
    Ziggster
    Starting to look into building my own friction shocks, and searching the interweebs, came across this thread. Was hoping for some more info, but this is what I plan on making. A few weeks ago I found some info on using some type of plastic? for the friction discs. Can’t find it now. lol! Will be using 1/4” plates.
    Deutscher and saltflats like this.
  18. cfmvw
    cfmvw
    Maybe you were thinking delrin? That is some tough material, but it machines real nice.
  19. seb fontana
    seb fontana
    from ct
    Delrin is slippery!
  20. Ziggster
    Ziggster
  21. Ziggster
    Ziggster
    Deutscher likes this.
  22. Ziggster
    Ziggster
    The guy in this vid talks about using Beechwood soaked in beef tallow. Hmmm. Yummy. lol!
  23. saltflats
    saltflats
    from Missouri
    Wasn't leather used?
  24. Ziggster
    Ziggster
    I think so from what I recall reading. Thinking the wood was soaked in beef tallow, I searched “oil impregnated plastic”, and Google AI came up with this. So, I’m guessing this “new” friction mat’l is some is likely made of Nyloil, TIVAR, or Nylatron.
  25. twenty8
    twenty8
    Oil impregnated plastic will do the exact opposite of what you need to happen. It is meant to reduce friction.
  26. Ziggster
    Ziggster
    No expert, but there seems to be a balance required. There will always be friction between two surfaces referred to as the coefficient of friction, but the aim is to make it so that the materials in contact do not “stick” and cause a “jerking” movement. That’s why the old guy in the vid mentions soaking the Beechwood in boiling beef tallow. If you wanted maximum friction you would use something like sandpaper. Even the wood discs use br*** discs between them to have a smooth surface to work against.
  27. Ziggster
    Ziggster
    Found some 1/4” thk TIVAR mat’l on Amazon. Kind of expensive. Probably could find it cheaper elsewhere though. Beechwood in town is much cheaper, so will likely try that route out first.
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think I bought my friction discs from Speedway.
  29. Happydaze
    Happydaze
    I'm not sure about in the US but in the UK we have trailer stabilisers called Bulldogs that are in fact a friction shock, albeit mounted horizontally. The disc is made of a brake shoe lining type material (no asbestos). Pretty inexpensive. 4" diameter. They do wear but I've never replaced a disc in many thousands of miles of towing. Admittedly using as a vertical friction shock I guess would increase the wear rate but I expect it would be acceptable. Example link below.
    https://www.leisureshopdirect.com/c...biliser-spare-parts/bulldog-stabiliser-spares
    I wonder if brake lining material were available in flat sheet such discs could readily be reproduced?
    Edit. A quick Googling of flat sheet brake lining revealed a myriad of possibilities!
    Chris
    Deutscher and Ziggster like this.
  30. Ziggster
    Ziggster
    Yeah, they have these.
