Homemade lowering blocks ?
Discussion in 'The Hokey Ass Message Board' started by plmczy, May 14, 2008.
  1. plmczy
    plmczy
    I scrounged a piece of 2x2x3/16 wall square tubing out of the s**** dumpster at work. I plan on making a set of 2" lowering blocks from it. My question is should I cap the ends of the tube for support or leave them open? Thanks for the help. later shawn
  2. LabRat
    LabRat
    Will look neater but not nessesary , what is though is to drill a hole on the top side to locate it on the leaf spring ...
  3. 47bob
    47bob
    Capping them could only make them stronger.
  4. lostn51
    lostn51
    from Tennessee
    id cap them if i was you just to be safe!!
  5. plmczy
    plmczy
    Thanks guy's. I plan on cutting down a shouldered bolt so that a little bit sticks out the top to locate in the hole on my spring perches. I'm gonna put two heavy spot welds on each side of the bolt head inside the block to keep it there. Then drill a hole on the bottom to locate it on the spring pack. later shawn
  6. chaddilac
    chaddilac
    3/16" - I'd definitely cap the ends for added strength.
    1/4" -I wouldn't even mess with caps!
  7. Insane 1
    Insane 1
    from Ennis TX
    You know you can buy a good set of aluminium 2" angled lowering blocks, w/u-bolts for like... less than $40 right?
  8. sickboy713
    sickboy713
    from oildale
    get a long drill bit. (1/4") long enough to go through both top and bottom. that way they are located the same. on the top use an allen head bolt for your pin in the rearend. drill the top hole to fit the diam. of the bolt. just bolt it to the tubing. on the bottom drill the hole to fit the pin on the springs. very easy and works well. i have made several blocks like this for my stockcar.
  9. 1951bomber
    1951bomber
    from atwater Ca
  10. old dirt tracker
    old dirt tracker
    from phoenix
    i make them all the time like this go for it.
  11. PollockzRodz
    PollockzRodz
    Im down with the saftey part of things so I would say cap um. Like Insane said you can buy lowering blocks with bolts so cheap it might not even be worth the amount of time it takes you to make up the s**** ones. Just a though. Advance Auto, PepBoys, AutoZone they all sell um. -Jon
  12. KJSR
    KJSR
    from Utah
    Sure you can go to one of the quality auto part stores and buy some top notch lowering blocks (which are more than likely made to the exacting standards of CHINA or another high end suppling country) or make your own....in your own shop or garage...here in the US. I say make your own!
    Oh yeah the original question....I would cap them for both strength and looks.
  13. PollockzRodz
    PollockzRodz
    hahaha I thought about what I said after I said it lol Put my fist in my mouth on this one. I say build um also its about the quality not the price or time. -Jon
  14. RATFINKFOREVER
    RATFINKFOREVER
    from Canada Eh
    ya but whats the fun it that
  15. 39 Ford
    39 Ford
    You will also need shackles, the last set I had made at a spring shop cost me $30.00 you can buy a packaged set for about the same price, so think about it.
  16. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I just got some u bolts last nite, Im going to grab 2 pieces of 2x6 tubing to do the same thing. Yeah yeah before all the safety professors chime in I know about scrub line and blah blah, this is just to scoot the *** end down while its sitting waiting to be finished and maybe get it around town for a few months. Stock ride height and the chop is making it look worse.
  17. R Pope
    R Pope
    2x6 tubing?! You do realize there'll be no suspension travel at all with that much block, without some major frame work (C'ing, etc.)?
  18. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    No, no clue. Thanx professor... :rolleyes:
  19. glassguy
    glassguy
    how ironic. seems like just yesterday i was talkin bout something like this
  20. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Yeah I'm going to do it, but just to move it around my street and MAAAYBE the in town cruise nite. Outside that Im too scared to drive w/ 6" blocks. :eek:
  21. plmczy
    plmczy
    Yeah I know I could buy them, amatter of fact I looked into it down a Carlisle. I'm sticking with my factory narrow springs and the only thing thats available is just the blocks no u-bolts. Since I had this tubing and the s**** pieces to cap the ends, the only thing I need is new u-bolts. In my situation every buck I can save is better for me in the long run(at least that's what I keep tellin myself,haha). Thanks guy's. later shawn
    Sickboy, thanks for the tip that's even better than my lamo idea.
  22. 46mopar
    46mopar
    dumpster driver....
  23. VonCi$co
    VonCi$co
    UH OH He used the "MT" Word your screwed now!
  24. 3/16" square tubing, no need to cap the ends, it will not collapse, for esthetic reasons, I would thou.
  25. The Hank
    The Hank
    from CO
    what about hockey pucks??
  26. kenagain
    kenagain
    from so cal
    too dam hard to drill n welding them is worse
    Ken
  27. sickboy713
    sickboy713
    from oildale
    glad it was of some help. enjoy
  28. Jack
    Jack
    from Austin Tx
    I built these for my buddies 53 Chevy. Used 1/4" 2x4 and 1/4 " plate to box the ends. Sectioned 1/4" out of the tubing to make it fit the narrow springs and had a local spring place make the U-bolts. Got my TIG learn on making these. Then my buddy Mike (Gl***bender) threw on some quick stripes.
  29. LabRat
    LabRat
    That's a damn nice set o blocks you got there , now they beat the **** out of any store bought ones !
  30. krooser
    krooser
    My buddy builds his own but with a twist...they double as the leaf spring pads. He just cuts the axle tube radius in the rectangular tubing and welds 'em to the axle tube...strong and simple.
