Homemade lowering blocks ?
Discussion in 'The Hokey Ass Message Board' started by plmczy, May 14, 2008.
  1. Richcaz
    Richcaz
    from Austin
    Those blocks are sweet!
  2. harleybraydin
    harleybraydin
    from Roscoe IL
    I thought that was half of the reason we do what we do. I would rather make my own stuff than buy it.
  3. Jack
    Jack
    from Austin Tx
    You should know. Glad to see they're holding up.
  4. Be sure to check your drive shaft clearances under your frame cross braces and possibly your floor board clearances before you drive it.
    _______________
  5. 19Fordy
    19Fordy
    Cap them, BUT make it so the end pieces fits INSIDE the tubing. Chamfer the edges first before inserting. Then weld.
  6. 296 V8
    296 V8
    from Nor~Cal
    Consider doing it this way
    Use 2 x 4 x 120 and turn the tube the other way
    Cut to amount of drop you want
    Cut one end on a angle if need be (to change angle)
    Cap ends (hole in one, locating stud in the other)
  7. 73RR
    73RR
    If you cap the ends be sure to seal up the top pin so you don't have to deal with water getting in....
