Projects Homemade roadster top
Discussion in 'Traditional Hot Rods' started by thompsonwayne1, Jun 1, 2016.
  1. thompsonwayne1
    thompsonwayne1
    Here is my attempt at a homemade roadster top. 1" foam sheeting from Home Depot covered with fibergl*** drywall tape, 2 coats of brushed on wood glue and a coat of spray on truck bed liner.
    Goes on and off in 5 minutes and weighs about 20 pounds. I put some speakers and stuff in the ceiling. It keeps the wind off my significant other (the war department)
    My brother says it looks like the Munsters car The "frames" around the side windows would look better if the weren't so wide.
    Texas Webb likes this.
  2. wsdad
    wsdad
    What did you use to hold it in place so the wind doesn't blow it off?
  3. thompsonwayne1
    thompsonwayne1
    The front of it has a wood frame with 1/4-20 screws down through the roof. They screw into rod couplings that have been fastened into the windshield pillars. The holes in the roof are plugged with flush fitting 1" conduit knockout seals, same color as the roof You hardly see them.
    The rear has a form fitting resin frame on the bottom about 1" thick that has four 1/4-20 bolts into the body. The resin frame was built by pouring liquid resin into a dam on top of the body. The dam was made of cardboard and thin sheet metal and lined with blue tape. "Pam" cooking spray was used as mold release agent. Once the resin cured all the tape and cardboard was stripped off and the foam was glued to the resin frame.
    A learning process and very time consuming, but I could build another one in 1/4 the time.
  4. woodhawg
    woodhawg
    Other that the frames you mention I think you did a damned nice job. Does it work and actually make the cabin more comfortable?
  5. bct
    bct
    Nice work.
  6. G V Gordon
    G V Gordon
    from Enid OK
    If I had just read the materials list I would have expected something awful but gotta say I don't hate it, and it works as intended... good for you.
  7. Jibs
    Jibs
    Whats the speed rating?
  8. Texas Webb
    Texas Webb
    Looks sharp and good job.
  9. dumprat
    dumprat
    from b.c.
    Ya know if you filled the side windows and painted it white it would look quite "Carson,ish"
  10. thompsonwayne1
    thompsonwayne1
    I don't know how fast it would handle but I seldom drive this old rat over 65. Maybe I'll eliminate the side windows. That would be easier than trying to re do them
    Atwater Mike likes this.
  11. indyjps
    indyjps
    Looks good, you actually have a perfect "plug" if you wanted to pull a mold and lay up a fibergl*** top in the future.
  12. Atwater Mike
    Atwater Mike
    Good call...I'd also look at a 'California rear window' with frame. Thin chrome frame would bring that top right into the winner's circle.
    Shape/profile is great, fits the body nicely.
    The quarter windows were a big red flag to me... I also have '27s...Nice work!
  13. ol'stinky
    ol'stinky
    from New Jersey
    I was thinking the same thing! Maybe some spray glue and actually cover it in Naugahyde?
  14. wsdad
    wsdad
  15. RidgeRunner
    RidgeRunner
    from Western MA
    Interesting rear locating bars.
    Ed
  16. 26 roadster
    26 roadster
    This was my lift off top for my 27 back in 1983 at Kernville, CA Kernville 83.jpg
  17. Well I was expecting a Carson style top, that looks pretty good ( not tat a Carson style wouldn't look good). Pleasantly surprised.
  18. chessterd5
    chessterd5
    from u.s.a.
    I like it. The way you made it was very original. I think if you did trim down the window frames it would look more refined. If it had a trim piece going around the edge of the roof like a hardtop coupe model it would look more natural. And, maybe the two side trim pieces that run up the back from the trunk to the roof. Since the top is made from foam, the trim pieces could be milled from aluminum or hard wood with a router. Then stained to match, or chromed. There are even companies that will cut a knife to your profile for a router. If you want to..., you could look at a bunch of pictures of 1927 coupes & try to make it look like a coupe top, since that is kinda what you've done. Some small details like that would really make it look nice. I like it!
