Projects Homemade shoebox p/u
Discussion in 'Traditional Hot Rods' started by rocsas, Dec 14, 2019.
  1. rocsas
    rocsas
    from colorado
    This is a project I've been working on for a bit now, we found a rusty 51 ford for sale that was gone beyond saving, but the front doors and roof were in ok shape.
    I had a random vision in my head and took a saw to it, I had no regrets as it was a parts car at best plus the back was cut for a couch.
    I started by cutting the body from the b pillar forward, and with that base I searched for a frame, I found what I believe was a late 20s Chevy with parallel leaf springs that has been sitting in a feild. And it used to be converted into a trailer to tow behind a tractor at a farm. I then stepped the front of it and mounted my engine of choice.
    It is a 59-ab Flathead that I picked out of a different feild with a 4 speed behind it
    From here I took my measurements and cut the rockers off the body due to them being rust, took 10 inches out of the front of the body and 12 out of the back so that it tapers and channeled it 7 inches. I was going to chop it but decided against it. I then mounted it to the frame IMG_20191208_092423.jpg
    After this I found were on my frame I could step it up plus the rear of the frame was cracked and not safe, so I stepped it up roughly 12 inches and made the new back using box tubing and the rear out of a old Jeep Cherokee, I wish it was something else but it's all I have and it works with my budget IMG_20191207_161901.jpg IMG_20191208_101731.jpg
    The front needs lowered but it's close to where I want it
    Now that I have narrowed the body I must narrow the dash I'm using the original from the car IMG_20190825_151624.jpg IMG_20191212_182950.jpg
    And this is where I am at as of now I'm still deciding on the back of the car but the original idea was to make it into a truck
    I hope you like it and any input is welcome
    Thank you,
    Dillon
  2. low budget
    low budget
    from Central Ky
    That’s using what you have, I hope to see you make something out of it and I will be looking foreword to seeing it come together. I may have more input after work today
  3. GordonC
    GordonC
    Good for you using the things you have available. Will be different but should be cool.
  4. rocsas
    rocsas
    from colorado
    Thanks, that's the goal for this project is stuff laying around or handbuilt.
    I found a few more pieces for the ol hotrod today, I got some pedals, a battery box, a hood my brother had laying around im going cut up,and a old pair of headers I'm gonna cut up with a driveshaft and make a set of lake headers IMG_20191215_133023.jpg IMG_20191215_134139.jpg
    chryslerfan55 and kiwijeff like this.
  5. Thing looks wild!! cant wait to see more progress!
  6. A shoebox pickup! I love it!
  7. low budget
    low budget
    from Central Ky
    Less Z in the back would help it in my opinion. (smaller tire in front will help some too)
    duecesteve, Just Gary and kiwijeff like this.
  8. low budget
    low budget
    from Central Ky
    RPU? Rough, rough sketch:D but I think you will make something out of it....Nice shop!
  9. sloppy jalopies
    sloppy jalopies
    hmmmmm…. roadster pick up...
    a lot less of the difficult body work than building a cab back...
    also, in the future you may stumble onto another rusty body you like,
    and it may fit that double stepped ch***is...
    …. go rocus go !
  10. low budget
    low budget
    from Central Ky
  11. rocsas
    rocsas
    from colorado
    I think an rpu would be cool but I'm not worried about the body work I'm in this car for the Long haul and to challenge myself so anybody works that's thrown my way I'll take it I do like the 49 Ford rear cab idea though, the car will be low when done so I think I'm going to keep the step in the back the height it's at plus I want to hide a lot of the stuff for the car under the frame back there, I'm also toying around with a different idea instead of a pickup. received_538611833360406.jpeg
  12. Chopp'd49
    Chopp'd49
    Use the Hood to Create a Boattail Shoebox....???
    scotty t likes this.
  13. rocsas
    rocsas
    from colorado
    Got the dash mounted today and the hood cut down to fit, apparently 41 Chevy hoods fit perfect on a narrowed 51 Ford also another picture of the Flathead, I never get tired of looking at it, the front of the car definitely needs to come down a few inches IMG_20191217_191510.jpg IMG_20191217_191519.jpg IMG_20191217_190413.jpg IMG_20191217_184125.jpg
  14. 19Fordy
    19Fordy
    You are good. Got to give you credit.
    Keep cranking and keep us posted.
  15. rocsas
    rocsas
    from colorado
    Thank you and I will keep you posted as I build I'm mounting the steering column as we speak LOL
  16. rocsas
    rocsas
    from colorado
    I think woodie is going to be my choice of action but I did set the hood on the back for giggles and oddly enough the body lines of the hood fit perfect to the back of the cab o_Oo_O
    bchctybob, low budget and Chopp'd49 like this.
  17. rocsas
    rocsas
    from colorado
    Here is where I'm I'm calling it for the night I mounted the steering column and was able to sit behind the wheel for the first time I quickly realized after sitting in it and pretend I'm driving it the shifter hits the steering wheel so I heated that up and bent it right up IMG_20191217_201243.jpg
    low budget likes this.
  18. sloppy jalopies
    sloppy jalopies
    did you make vroom noises ? I have and when doing so I have never missed a shift...
    Woogeroo and fattboyzz like this.
  19. rocsas
    rocsas
    from colorado
    I also vroom changed pitches while downshifting and the occasional peeling out and dumping the clutch screetches
  20. mitch 36
    mitch 36
    At first I actually thought " OH MY GOSH" but now after seeing your progress I just have to say that you've got some vision and mad skills. I like where this is going , keep at it :) ,,,Mitch.
  21. Interesting. I like what you did with the dash. :)
  22. rocsas
    rocsas
    from colorado
    Took a break from the hot rod and built a trailer for my job today got a lot of welding practice in I am a manager for the top haunted house in Colorado terror in the corn I'm lucky enough all year I get to scare people or build things that scare people for a living, but sometimes I do jobs for the farm it's at, like this goose neck trailer that tows behind a John Deere Gator, not hotrod related but a little tidbit about myself, also a picture of me and one of my characters I use to chase people with chainsaws, fun fact our chainsaw we use is from the 1950s and still kicking IMG_20191219_165612.jpg IMG_20191219_165349.jpg IMG_20191219_165334.jpg FB_IMG_1576809607927.jpg FB_IMG_1576809076943.jpg
    Surfcityrocker and Outback like this.
  23. Mr48chev
    Had me worried with the chain saw and ****** face photo, thought you had had kick back.
    Normally I just flat cannot get into this type of build but it is more than obvious that you saved pieces that otherwise would have been tossed for s**** and that works for me.
    Outback likes this.
  24. rocsas
    rocsas
    from colorado
    Yes this car was about to be parted out and s**** I see it as a way of me giving it a second lease on life also the frame was just going to rot in that field along with that engine
  25. low budget
    low budget
    from Central Ky
    If you were closer @Old wolf has a F1 panel truck roof that someone tried to mate to a 58 Desoto:D
  26. Ive got the exact same model Poulan chainsaw that leather face used in the Chain Saw m***acre. Ive had it running. However the diaphragm in the carb is bad and it needs a kit or new carb. There is a chainsaw thread on the antiquated forums. massacre chainsaw 001.JPG massacre chainsaw 002.JPG
  27. Ive already gave that Desoto Ford cross away. I intend to go help the guy get it.
    Outback and low budget like this.
  28. low budget
    low budget
    from Central Ky
  29. rocsas
    rocsas
    from colorado
    That thing is a sight to be seen for sure lol
  30. rocsas
    rocsas
    from colorado
    That thing is sweet maybe I will look into that thread I'm always looking for ideas and cool antiques for our haunted house
    duecesteve likes this.
