Homemade windshield frame...???
Discussion in 'The Hokey Ass Message Board' started by RotHod, Mar 13, 2005.
  1. RotHod
    RotHod
    from So Cal
    Does anyone have any tech on making a windshield from scratch? Preferably for a 26-27 T roadster, square tubing or round tubing, bending to shape and making the channel for the gl***. Ive only seen frames made to fit out of existing frames which I dont even have. I only have the stanchions.
    Thanks
  2. james
    james
    Do a search, seem like this came up last week or so.
  3. old beet
    old beet
    Here is a 27 with only the stanchions,..............OLDBEET
  4. BELLM
    BELLM
    Thats a good way to go, buddy has a 27 roadster, gl*** mounted directly in stanchions. Looks much cleaner than my 27 with the lower 1/2 of stock windshield frame.
  5. Nimrod
    Nimrod
    Someone on here did a tech article of just that on here about a month ago. Made a model A frame using water pipe I believe.
    I personally don't like 'em with the gl*** mounted to the stanchions, looks clean....a little too clean, says "street rod" to me.
  6. alchemy
    alchemy
  7. MBL
    MBL
    I made one out of copper tubing....first bend to match the cowl...then cut a slice in the tube to fit the gl*** in...I'm not running it now because I found an original. but it was for a 1926 T roadster...I just braised it together.
    Tim
    MBL
  8. Gregg Pellicer
    Gregg Pellicer
    I made one for my 26 out of electrical conduit.cut the slot withsheet metal shear.s (air powered) they left a 1/4 in. slot for the gl***. that stuff polish,s up real good also then just spray it with some clear.GREGG
  9. RotHod
    RotHod
    from So Cal
    I will give that one a try, what diameter did you use? I guess some thin wall tubing should work as well. I will have to figure out what to use for the 1/4" slot, maybe a machine shop can handle it.
    Thanks for all the input, got any more pictures?
  10. Winfab
    Winfab
    I made a windshield frame for my '23 T from 1/2" X 1/2" X .065" square tubing with one side carefully ripped off in a bandsaw to form a channel. Bedded the gl*** in the urethane stuff, that comes in a caulking tube, that they use to bed windshields in newer cars. Trimmed the excess off with a razor blade and it looks like it is a "factory" deal. I was told by several bodymen to NOT use silicone. I used mild steel tubing, but wish I had used stainless like I did for the rest of the support pieces.
  11. continentaljohn
    continentaljohn
    You can cut as slot with a cut off wheel.. It's gonna take a few wheels and a bit more time but it can be done.. A simple fixture would help too..
  12. There was a good post on theis a while back.
    This is one job that i have got to do soon
  13. Gregg Pellicer
    Gregg Pellicer
    To cut the slot I used air powered sheetmetal shear. It leaves a 1/4 in slot.I believe the tube size was 3/4 maybe 1in.Just go grab a piece and see if it lok's right to you.I made one out of1/2in it looked to small to me.If you can find the book T-Bucket Roadster by Chester Greenhalgh it has a chapter on building one though not the same as a 26/27 it gives a pretty good idea of what to do.The book is usually at barnes and noble you can just go look at it there.GREGG
  14. RotHod
    RotHod
    from So Cal
    It might be a good idea to make the channel for the gl*** slightly larger than a 1/4" to allow room for the silicone or rubber what ever is used. I think I will just silicone on mine to make it simple.
  15. kustombuilder
    kustombuilder
    from Novi, MI
    like Winfab said. use the black urethane. it comes in a caulk tube.
