Technical Hood clearance
Discussion in 'The Hokey Ass Message Board' started by JorgeFleet48, Sep 8, 2023.
  1. JorgeFleet48
    JorgeFleet48
    I have a 1948 chevy fleetmaster. (Working on engine, body is at a different location)
    Does anyone knows the gap size between the top of the carb and the hood?
    Working on a different style carb cover and am hoping it clears....
    Thanks in advance
  2. 05snopro440
    05snopro440
    You haven't given much information. Is it the stock engine? Stock carb/manifold? The hood is generally pretty tall on those cars and provides lots of engine clearance.
    Special Ed and JorgeFleet48 like this.
  3. BJR
    BJR
    I would think you would have to put a blower on a V8 to have hood clearance problems on a 48 Chevy.
  4. JorgeFleet48
    JorgeFleet48
    Stock all around
  5. vtx1800
    vtx1800
    I'd take a level and lay it on the hood, I'd suspect that "level" would be slightly above the hood, measure how much and then raise the hood (If I remember right the springs aren't great..use a prop rod to hold it a little higher, then use your level from about where the hood was, you know how much drop there is...you should be able to visualize how much room you have. I'd agree that you could probably mount a blower and still clear, good luck:)
    EDIT....I didn't read close enough..no engine:( My idea is of NO value.
  6. MCjim
    MCjim
    from soCal
    Stock...looks like a lot of roooom
    05snopro440 likes this.
  7. fordor41
    fordor41
    get some modelling clay, put a gob where ever and shut the hood. that will tell how much clearance
    JorgeFleet48 and vtx1800 like this.
  8. alchemy
    alchemy
    For some people, reading is a problem. He said his body and engine were not together. How could he use a “gob” of clay?
  9. warhorseracing
    warhorseracing
    from cameron wv
    When you get the engine installed put a 2' long piece of all thread in the carburetor where the air cleaner stud goes. Close the hood or attempt to and where the rod dents the hood drill a hole then fully close the hood. Mark the all thread where it comes through the hood and cut it off. Measure the length and VIOLA. You will know how much clearance you have and a new hole in your hood to either weld up or let the heat out of.
  10. 05snopro440
    05snopro440
    The engine and the body aren't in the same location, how do you suggest he figures that?
    JorgeFleet48 and Just Gary like this.
  11. theHIGHLANDER
    theHIGHLANDER
    Unless you're building a Chevy version of the OG Ramchargers "High and Mighty" you probably have nothing to worry about. You did say stock stuff so...
    JorgeFleet48 and 05snopro440 like this.
  12. ekimneirbo
    ekimneirbo
    from Brooks Ky
    From looking at the pictures, it appears that any normal engine in these cars is going to sit about as high as the fenders or slightly lower. So I'd guess that you have the full height of the hood above the motor as a minimum.
    JorgeFleet48 likes this.
  13. rustydusty
    rustydusty
    Are you actually designing something taller than the original air cleaner??
  14. 05snopro440
    05snopro440
    You might refer to stovebolt.com to ask your question if you want an accurate measurement on a stocker.
  15. JorgeFleet48
    JorgeFleet48
    here is what i was doing gents. just something a little different for some special occasions aka shows. by the looks of it, i am about 1/2 inch taller than the regular carb cap cover.
    once i get the body down here in the spring i will know 100%, but for now it looks good in the garage lol 20230910_153449.jpg
    05snopro440 and theHIGHLANDER like this.
  16. theHIGHLANDER
    theHIGHLANDER
    Wow, "bombs awaay...!"
  17. 19Eddy30
    19Eddy30
    from VA
    Just Thoughts ,
    If body frame @ different location , can some one take a measurement from Frame , center of motor mount bolt up to bottom inside of Hood ,
    Or some one with stock 48 Fleet master
    Take a Measurement from a given location to bottom inside of hood,
    ( I think of this like reading a Blue Print)
    A Stocker , Measurement from top of intake ? Or something as A reference point ???
    If some one has a Stocker A ball of Tinfoil will give a Measurement
    Think a little out side of box ,:)
  18. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Don't drive it near the Whitehouse............:D they may not see the humor in it.
    JorgeFleet48 and warhorseracing like this.
