Technical hood hold downs
Discussion in 'Traditional Hot Rods' started by easyrider47, Feb 17, 2014.
  1. easyrider47
    easyrider47
    I have a 32 style hood for my 29 Model A. I plan on running just the two hood tops and I have the 32 style hood retainers but I don't knows how I'm going to hold it down. Have any of you done this before? I want the hood sides open top show off the header and intake and carb and polished valve cover. HELP !!!
  2. Larry Pearsall
    Larry Pearsall
    I've welded a bolt on each end of the hood (inside bead roll) and added tabs to the firewall and grill shell . Unseen except the tabs when hood is open. A wingnut is all I use to tighten.. Its been on there for 20 years..
  3. Try "Restoration Hardware", (310) 458-7992, if you are interested in the springs that they used to use on sprint cars to hold the hoods down. Wish I had a picture but they may have a web site or may be able to explain it better.
    Charlie Stephens
  4. gearheadbill
    gearheadbill
    On my 36 pickup I fabbed a ring which fastened to the lower inside edge of each hood side...ran a bungee cord between the 2. Hood tops are held onto the car by the center hinge. Bungees keep the lower edge of the tops clamped down and against the cowl. Easy to remove and the bungee is out of sight. Cheap but effective.
  5. Frank32
    Frank32
    I made a rod that is peaked like a half triangle (slight) that slips right into rod channels, my hood has the sides removed (the rod slides into this). Take a look at the pictures. I can take more pictures if needed. You will notice the rod is black in picture. I cannot take credit for this, I copied this from a fellow hot rodder.
  6. bbrroowwnn
    bbrroowwnn
    from Drums PA
    this is what I did with mine...I use the rubber t-handle type with the ball end on them.....bolted flatstock to firewall and grill shell...welded the c-brackets for the balls on to the flatstock....then just used existing hinge hoops underneath the hood with a short piece of rod through the hinge on the bracket......works like a dream.......turned out pretty good , I think anyway[​IMG]
  7. Muttley
    Muttley
    How about some Dzus Fasteners?
  8. Kume
    Kume
  9. Muttley
    Muttley
    The car? I have no idea, just Googled "Dzus Fasteners" to give the OP an idea what I was talking about in case he didnt already know.
  10. HOTRODPRIMER
    HOTRODPRIMER
    There are a bunch of ways to do this,I used a screen door spring stretched between the underside of the two hood tops. HRP
  11. BigEd
    BigEd
  12. Limeworks has some nice stuff.... or you can make your own like I did for about $40.00.
  13. flyin-t
    flyin-t
    Not very original, but my old T wasn't nearly as nice as the cars already in this thread. I was going for an old gow look.
  14. denis4x4
    denis4x4
    from Colorado
    I used harness leather, coachman loops and horse collar latches. Bought the stainless steel zig-zag springs 15 years ago for $100 bucks.
  15. GCJones
    GCJones
