Technical Hood making ideas
Discussion in 'Traditional Hot Rods' started by WP38, Jul 8, 2017.
  1. WP38
    WP38
    I have a 1938 international on a 1948 Merc frame, So I need to build a hood nothing would fit, I am thinking of leaving the sides open with a hinge set up to open each side,
    Looking for some pictures or thoughts on building one, I have a hinge, Thats all,
    Thanks
  2. sloppy jalopies
    sloppy jalopies
    find a hood that fits your cowl, even if you can only use a few inches... build a perimeter then fill the gaps / hole...
  3. lostone
    lostone
    from kansas
    ^^^^^ agreed, I'd build the perimeter out of steel rod, maybe 1/4", then build sheet metal to rod and weld up.
  4. HOTRODPRIMER
    HOTRODPRIMER
    The last time I made a hood was for a 31 Model A,I started with poster board and scissors,I laid it across the top and fit it to the contour to be covered,once I was satisfied with the fit I transferred it to sheet metal,I let the sides of the hood extend down about a 1 where I could bend it under to stiffen the edge.
    the next step was to use a oxygen cylinder and hand shaped it to fit,it takes a lot of patience and putting it on and taking it off.
    When I was happy with the fit I considered leaving it one piece but I ended up measuring the hinge and deducted the width of the hinge and removed that from the center of the hood,making it a two piece hood,I then put the hood in a brake and bent the sides inward to stiffen them,then tacked the hinge to the hood.
    It turned out great,I used a spring loaded deadbolt to hold the hood down. HRP
  5. WP38
    WP38
    Thanks guys
  6. upspirate
    upspirate
    I have not done this, but I have heard if you use roofing paper , it's stiff and will hold shape better for a pattern. Basicly what HRP did, but with a stiffer pattern material
  7. jimmy six
    jimmy six
    PM sent...
    AmishMike likes this.
  8. WP38
    WP38
    Thanks I have roofing paper.
  9. upspirate
    upspirate
    Let us know how that works so I don't p*** around BS !!!
  10. Marty Strode
    Marty Strode
    If you have access to some linoleum (they call it vinyl flooring these days), it works real well. It follows the shape of the curves, and stays pretty rigid. I would use .063 - 3003 alloy aluminum.
  11. 34FordConv
    34FordConv
  12. WP38
    WP38
