Technical Hood props - 32
Discussion in 'Traditional Hot Rods' started by Jasper234, Mar 3, 2022.
  1. Jasper234
    Jasper234
    Hi
    Does anyone know of, or has anyone made up, a hood prop for a 30s car which has open sides (ie just for the tops)?
    I’m using a pair of rootlieb louvred tops and want to find some props that locate properly so they don’t slip or move, scratching the paint. If you have pics of what you’ve made or any references to kits available, that would be great
    thanks guys
  2. pprather
    pprather
    Bump to the top.
  3. Jasper234
    Jasper234
    Thanks buddy
  4. Blade58
    Blade58
    from apopka ,Fl
  5. Kiwi 4d
    Kiwi 4d
    Ah no @Blade58 this won’t work with the op requesting hood top only , this will be too low.
  6. Jasper234
    Jasper234
    Thanks for the pic @Blade58 - no hood sides, so would need something longer I think.
  7. V8 Bob
    V8 Bob
    I made simple rods that run from small spring pin brackets on the firewall to the the pins.
    Kiwi 4d and Jim Bouchard like this.
  8. modagger
    modagger
    I believe we have pretty much the same hood and here’s what I came up with for props, and when not in use, they’re stored in the trunk.
    jeff 6A88D7A5-3C8A-4F31-819B-4A31746B36BC.jpeg 942E1A56-2F66-44E2-875D-76415C58501B.jpeg E4EFBD42-0925-4DA8-8353-EA8AEA543F05.jpeg E19DD4E4-C501-49A7-8CA7-6EB827C2CBA8.jpeg
  9. JWL115C
    JWL115C
    I have used ⅜" or ½" tubing cut to length with rubber feet on both ends. Works well and looks good.
  10. Bandit Billy
    Bandit Billy
    I have a one piece hood top only, but just food for thought. When I was building the car I added a provision for a screw in studs (easily retrofitted with nuts on the back side). The SS prop arm has a spring loaded quick release that attaches to the stud so a gust of wind cannot blow it off the perch. When not in use it stores inside the hood lip on a spring catch. I think I got it from the same company that made the hinge system I used. I cannot recall who that was but it may have been a Hagan piece.
  11. pprather
    pprather
  12. Jasper234
    Jasper234
    Thanks for these - really helpful. I have a few ideas now. Have a great weekend.
    pprather likes this.
