Hoodless in the Rain????
Discussion in 'The Hokey Ass Message Board' started by Kensey, May 20, 2013.
  1. Kensey
    Kensey
    from Pittsburgh
    OK, super stupid question.....
    I have my first model A, stock 4-banger. Naturally I've started messing with it. I removed the hood without even thinking about it. Drove it to my parents house today and my mom says, "what do you do when it rains?"
    Me, "duh, good question!"
    Advice from experienced hoodless bad ***es please?
    Thanks,
    Kensey
  2. Tedders
    Tedders
    Roll up your window..
  3. F&J
    F&J
    Ok, here's a question for you.. :)
    In a pouring rainstorm, while you are driving at 50 mph with the revs up, and the fan whipping...do you suppose the rain is getting on the motor?
  4. 36DodgeRam
    36DodgeRam
    I had wondered the same thing. But last summer, I got caught driving thru a heavy rain, hoodless, my 331 never missed out. So I guess no worries. But I wonder if I get caught parked in the rain, will it start? I'm sure I will find out...
  5. The37Kid
    The37Kid
    Personally I like the look of FULL hoods, they make a Hot Rod look like a Dry Lakes race car. Wish someone could do a wind tunnel test to see how much slower any given car would go without a hood vs with one. Bob
  6. pinkynoegg
    pinkynoegg
    its just like water injecting your engine!
    Ive driven through many a rainstorm in my hoodless cars. when I park I cover the carbs, when its running its not a problem at all
  7. Master of None
    Master of None
    I bet you sit where you are if its raining with the stock solid exposed plug wire.
  8. F&J
    F&J
    Well, if a person had a *****in old school motor with cool stuff on it, running a full hood would be like asking Bette Page to put her shirt back on, or telling John Holmes to put pants on:confused:
  9. swifty
    swifty
    I don't run a hood on my coupe and it's never been a problem either driving or sitting.
    I've got Stellings and Hellings air cleaners on the tri-power, no fan, electronic ignition and my coil is mounted upside down on the firewall-which I've been told is a no-no.
  10. Carry a shower cap for overnighters or a good car cover a quality filter for driving..., tell momma no worries a little water just disipates. I dont do down pours but drive mine all the time in showers no problems
  11. trbomax
    trbomax
    When I was going to college,my 28 steel car(the one in my avitar) was my daily driver.Most of the time it went hoodless,even in the winter. Many times I remember cleaning snow off of the motor in the morning.It never caused a problem.
  12. mustang6147
    mustang6147
    from Kent, Ohio
    Ever ride your motorcycle in the rain?
  13. hiboy32
    hiboy32
    from Omaha, NE
    I too have to say running hoodless has had no ill effects in the rain. I ran hoodless with a well worn stock flathead to a well built fatty. Bet I have more rain miles then some have dry miles.
  14. Jokester
    Jokester
    I drive hoodless quite a bit. Got caught in the rain a lot. No problems, just drive.
    .bjb
  15. A Rodder
    A Rodder
    Mine sat outside for two nights in the rain last year at a car show.
    Now ill effects other than lots a rusted head bolts.
  16. Hackerbilt
    Hackerbilt
    Just be careful when parked in the rain. With modern engines, you can have water pool on top of the air breather and leak into the carb thru the wingnut hole.
    If you get enough in there, and it doesn't take all that much, you might hydraulic-lock a piston in the bore and bend a connecting rod!
    But...the thing is...doesn't a stock Model a banger use an updraft carb? ;) :D
  17. Kensey
    Kensey
    from Pittsburgh
    Yes, up draft carb.
    The spark plug wires are exposed on the connectors. Bad???
  18. Master of None
    Master of None
    When they get wet they will miss fire.
  19. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've driven my 27 through blinding rainstorms where the rain was like bullets and I couldn't see the cars in front of me, the motor never missed a beat. One time it was 5 hours coming home from Turkey Run at 70 mph all the way without a problem, except that I was drowned myself from having no top.
    I would have thought the distributor getting as wet as it has been many times would have shut it down, but it never did.
    Don
  20. aircoup
    aircoup
    yep have done it alot
  21. Mr48chev
    Just make sure you have a full can of WD-40 and a full roll of paper towels or those blue shop towels stashed in the car along with what ever tools you need to pop the distributor cap off. My truck has 120 louvers in the hood and that's just about as bad as no hood in hard rain.
  22. pasadenahotrod
    pasadenahotrod
    from Texas
    Driving in the rain is no problem. The problem occurs when you park, go into McDonalds to eat because you.re cold and soaked to the skin, then come out and your hoodless car starts right up but your buddy's car with a top hood only requires popping the cap and a shot of WD40 to get rolling again. Condensation will get you every time.
  23. 37hotrod
    37hotrod
    There was just a post on another thread about water getting into the engine through the valve cover breathers and hydrolocking the engine. I have a well louvered hood on the '35...no problems driving it in Oregon's liquid sunshine.
  24. ironandsteele
    ironandsteele
    Untrue.
    OP, you'll be fine-just drive it.
  25. desotot
    desotot
    I drove my T with a desoto hemi for 14 yrs without a hood. I covered the carbs with a bag when it was parked. I had trouble couple of times when I ran without the plug wire covers and the tubes would fill up with rain water and it would take five miles to steam the water out of the tubes and it would smooth right out.
  26. I live on the edge of a rain forrest, and have to put up with plenty of rain. Only suffered a little water in dizzy. Apart from that, no problems. Its fun when others freak out wondering how you can still drive.
