Technical hooker cut outs
Discussion in 'The Hokey Ass Message Board' started by under1981.com, Jan 4, 2021.
  1. under1981.com
    under1981.com
    has anyone installed the ****** remote exhaust cut outs part # 11051HKR? it says they are tig welded at the factory but i'm trying to find out if they need to be tig welded when installing my new exhaust system or can they be mig welded to a normal exhaust system? not a complete stainless system. thanks for the help!
  2. wheeltramp brian
    wheeltramp brian
    They can be mig or tig welded to your exhaust no problem
  3. under1981.com
    under1981.com
    AWESOME!! Thanks so much for your help, i've been trying everywhere to get an answer. Thanks again, Murf!!
  4. Jalopy Joker
    Jalopy Joker
    for a higher level cut out system - saw on Hot Rod Garage install on cl***ic Caddy, after motor swap, ****** Blackheart "At***ude" Adjuster EVC - requires ****** Blackheart Dual Path Muffler : continuously variable valve position tuning options not possible with conventional exhaust cut outs
  5. Bigdavid
    Bigdavid
    from Tennessee
    Are you putting them on PK ?
