1952-59 Ford Hooking up an Electric Fan
Discussion in 'Off Topic Hot Rods & Customs' started by sircampsalot2, Jul 13, 2011.
  1. sircampsalot2
    sircampsalot2
    Can anyone tell me how an electric fan works? It has two wires coming from the Fan...I am wondering how to wire it up since the car or engine didnt have an electric fan on them before. I know I will need some sort of Temp Sender to hook to the engine and a Relay but thats about all I know about it. Thanks for any help
  2. sircampsalot2
    sircampsalot2
    I think I decided to go with this one from Summit Racing it has a good Instruction sheet with it also plus its agjustable.
  3. parklane
    parklane
    If your fan is like most, it will run clockwise and counter clockwise, by changing the power lead from one wire to the other. Yes you need a relay, a thermostat (adjustable is best) and a circuit breaker. The circuit breaker first, then the relay and thermostat. The other wire goes to ground.
  4. sircampsalot2
    sircampsalot2
  5. 1954vicky
    1954vicky
    from Reno, NV
    If this is a secondary fan you could just wire it to a switch.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Looks like a good choice for a relay kit,always run relays with electric fans and electric fuel pumps for safety.
