Hopped up 235 engine, 54 Chevy
Discussion in 'Traditional Hot Rods' started by TrueBeliever'54, Jun 2, 2016.
  1. I have a 1954 Chevrolet 210. Recently I had the engine rebored and rebuilt, bigger cam, Fenton headers and dual Fenton intake. Problem comes in with the carburetors. I bought 2 rebuilt Rochester B carbs off of ebay and the linkage it came with is all wrong. My engine shop has been on the phone with everybody you can think of and they nor I can figure out how to get these 2 running correctly. The throttle linkage is in a different spot than the original. Some people block off one carb but I am just disappointed, any help would be appreciated.
  2. Dave Downs
    Dave Downs
    from S.E. Penna
    Need pictures and an intro would be nice
  3. Sorry, my name is Chris. These new Rochester carbs came with linkage but it was not for this engine. The shop tried to customize it but the throttle needs to be pulled in the opposite direction as the original ImageUploadedByH.A.M.B.1464969710.820448.jpg ImageUploadedByH.A.M.B.1464969739.290540.jpg ImageUploadedByH.A.M.B.1464969755.693064.jpg ImageUploadedByH.A.M.B.1464969572.318436.jpg
    kiwijeff and Capt Chap like this.
  4. Tim O'Kelley
    Tim O'Kelley
    from texas
  5. Hellfish
    Hellfish
    Who would add a dual intake and then block one off?!? We had a similar problem with that same set up. Chevy made a number of different linkage configurations over the years for 216/235/261s... none of which came with dual carbs. What you need is a bellcrank the pulls instead of pushes (or vice versa). You may also need to bend your own linkage. It's just simple lengths of steel rod. Patricks carries a linkage set up which may or may not work for you, but he is a great source of knowledge and a great place to start.
    This was mine, but you can't really see the linkage or bell crank down on the block.
    Capt Chap likes this.
  6. We tried Patricks, but they couldn't figure it out either. Apparently there are 142 variations of the Rochester B carb, wish I knew that first.
  7. Inked Monkey
    Inked Monkey
    Have you checked out langdons stovebolt?
  8. steinauge
    steinauge
    from 1960
    Here is a pic of 2 model Bs using the standard Offy linkage. the linkage kit can be bought separately DSCN1143.JPG .I realize that your engine is a 235 and this one is a 250 but I have used 2X1 setups on both and the linkage setup is quite similar.
    gas pumper likes this.
  9. Thank you for the help. Found another roch b identical to my original. Hopefully it will be easier now that the arms are pulling in the correct position.
  10. Road Runner
    Road Runner
    Unless you have a 235 racing cam, you want 216 carbs for a dual carb intake.
    Rochester Bs have vacuum operated accelerator pumps, instead of mechanical and are harder to tune as you have to find the ideal springs for your engine and use.
    Carter W1 have mechanical pumps and that's what I use for my 235 with 261 cam.
    Auto-choke carbs can be converted with a kit to manual choke, which also gives less headaches.
    Check with @carbking - owner of the carburetorshop.com ...
    http://www.thecarburetorshop.com/Dual1barrelcarbs.htm
  11. 6inarow
    6inarow
    BINGO
    Stovebolt likes this.
  12. jkski
    jkski
    IMG_0040.JPG would go with carters easy to setup and rebuild with no leaking. Dual carbs for 216 are great on 235 .
  13. belair
    belair
    You gonna run those vice -grips?^^^ :)
  14. jkski
    jkski
    their the only billet I have. Just got to polish them
