Technical horizontal mounted coil
Discussion in 'The Hokey Ass Message Board' started by Old wolf, Mar 31, 2016.
  1. southcross2631
    southcross2631
    I ran one of those big ugly yellow coils from Accel on my O/T big block Camaro . One day it started running like ****. Checked the coil wire and it oil soaked from the coil. Wiped it off and put the coil wire back on it ran fine . Did again after about 3 months. Re mounted the coil vertically and never had that issue again. The same coil was on the car 2 years later when I sold it. First and last time I had an issue with coil mounting
    lothiandon1940 likes this.
  2. COCONUTS
    COCONUTS
    I have a 1933 Plymouth that had the original coil mounted within the firewall, coil on its side, with only the top sticking out. It was a hole and a bracket.
    dana barlow and rtp like this.
  3. Marcosmadness
    Marcosmadness
    I read in an industry newspaper (some years ago) that most coils that are removed are not bad and the problem is something else. Mounting the coil vertically would prevent the oil leaking out of the case since the case is sealed at the top. I had a coil that was continuously arcing to the frame during a rain storm and that coil got really hot.
  4. slim39
    slim39
    from pa
    39 plymouth had coil mounted though the firewall horizontally
  5. 23crate
    23crate
    from nz
    Interesting...
    My 63 Stude Lark, had a horizontally mount coil just behind the carb ..
    ive replaced 2 coils there, and since moved it, mounting it vertically on the firewall , Since replacing a further 2 new and a 3rd second hand one.. one new one lasted 700miles ..
    when horizontally mounted i used to have terminals vertical, reducing the visual wiring mess.
    but still annoyed the car is chewing them , ive about run out of things to check even the ignition switch isnt leaking volts when turned off
  6. Phil P
    Phil P
    Do you have the resister in the run circuit to the coil?
    Phil
    dana barlow likes this.
  7. 23crate
    23crate
    from nz
    thanks Phil,
    the latest coil has a resistor...previous versions didnt
    Al
  8. 23crate
    23crate
    from nz
    have chased down an older coil and condensor .. chucked them in the car which so far seems to start and run much better..
    i opened up a new failed condensor , and found alot of tin foil rolled into a tight wad, only filling about 3/4 the condensors cavity ...
    not sold on new stuff ...
  9. Turns
    Turns
    I always mount coils vertically and away from heat as a general guideline - I think I read that upside down vertical wasn't ideal.
    Cheers Turns
  10. Andy
    Andy
    I can't imagine it makes any difference. All my experience with SBC's was they all had vertically mounted coils. Even the 375 HP fuel motors had verticall coils mounted terminals up. I have never had a coil problem.
    57Fury440 likes this.
  11. 57Fury440
    57Fury440
    The Mopar's I have owned from the fifties and sixties all had horizontal mounted coils. I never had any problems. The OT Barracuda I bought new has its coil mounted that way also. All the small block Chevys that I have worked on had them that way too.
