Horn Ring
Discussion in 'The Hokey Ass Message Board' started by Gooch, May 15, 2009.
  1. Gooch
    Gooch
    from Baltimore
    I broke the horn ring on my 56 belvedere. Any idea if it can be welded. It's the full ring and I'd like to keep it if it can be fixed.
    Thanks!
  2. RoadkillCustoms
    RoadkillCustoms
    from Mesa, AZ
    It can be welded...you'll need to grind past the plating to get a clean weld. With thin stuff like this, I like to heat with a torch first to keep the weld speedy. Grind down and back into shape, then replate.
  3. Gooch
    Gooch
    from Baltimore
    Thanks Roadkill, TIG I presume?
    Thanks!
