Horrid vibration at about 40mph
Discussion in 'The Hokey Ass Message Board' started by punisher7, May 15, 2013.
  1. punisher7
    punisher7
    So I took my car on the freeway for the first time today and I have a horrible vibration at about 40. The vibration is bad on and off the gas. The car feels like it is going to explode. I know I have good motor mounts.
    I have a 48 Ford tudor with a 350/350 combo and a 10 bolt rear.
    Would I be best off having the driveshaft balanced and replace U-joints?
    Any suggestions would be appreciated as I don't want to spend to much money where it isn't needed.
    Thanks in advance.
  2. junk yard kid
    junk yard kid
    You just gotta check all the front end and suspension stuff first. It could be a loose bolt somewhere. Bias plys? Maybe its got flat spots from sitting. Bent wheel. who knows.
  3. I'd look at those ujoints first. It's unlikely but maybe a weight fell off the driveshaft.
  4. BronxMopars1
    BronxMopars1
    from Bronx, NYC
    Start simple, air pressure, make sure everything is tight that should be then have your tires balanced (if you haven't already) wheel alignment then move onto replacing parts
  5. alchemy
    alchemy
    Is the driveshaft long enough? How's the pinion angle?
    Why would you think you need to replace your new U-joints? Isn't everything new already? If not, look at all your old stuff to see if it is worn out. Could be any one of a million things.
  6. Gasserdriver
    Gasserdriver
    Might be caster shake, check the pre-load on your front axel bearings.
    Fred
  7. pitman
    pitman
  8. millersgarage
    millersgarage
    Lets start with, Where is the shake?
    In the steering wheel = Front suspension
    In the seat of your pants = Rear suspension and drive train.
    Start with the wheels, and work you way into the driveshaft, do the easy stuff first.
  9. Fenders
    Fenders
  10. MATACONCEPTS
    MATACONCEPTS
    Are all the lug nuts tight?
    Put the car in neutral & grab the driveshaft end, move it & check for play, on each end.
    Jack each wheel barely off the ground & grab it shake right/left & top/bottom.
  11. bigbob55
    bigbob55
    from Pittsburgh
    Like Millers garage says....don't waste time and money on guesses. where does the vibration originate....steering wheel shake is not drivetrain but suspension or wheels.
    Feeling in seat or floorboards is drivetrain but not front suspension . Run it up on a lift and look underneath....any change without weight of car on the ground....know where to look and you'll find the problem
  12. Re reading your post, I see you asked
    The way I'm reading it, you made the drive shaft, Non Drive shaft, shop build ?
    I make My own, But I was in the Automotive Protype Type Biz.
  13. black 62
    black 62
    from arkansas
    driveshafts need to be straight ---lots of people build their own with good results if it is straight and in phase it is not your problem...
  14. punisher7
    punisher7
    I didnt build the driveshaft. It was on the car when I got it. I had a tired out 305 in it and I swapped out a 355 over the winter. I never took it on the highway until today. The vibration is not in the front end. I jacked the car up and put it on stands.
    I fired it up and the drive shaft has a wobble to it in the rear. Just fine up at the trans, about a 1/4" wobble at the rear u joint. The wobble isn't in the rearend.
    After running it I took a straight edge and the driveshaft is not warped. I looked closer at the rear of the driveshaft and it looks like somebody hacked the driveshaft and rear u joint mount looks to be welded on crooked..
    I also looked and it appears that I could use a driveshaft that is about an inch longer.
    I called A1 driveshaft and they told me they won't add 1" to a drive shaft. The said that for an inch they would recommend a longer yoke. Either way I'm going to drop it off there Monday and see what they have to say.
  15. punisher7
    punisher7
    I took video of the wobble, but can't upload it with my phone.
  16. 47ragtop
    47ragtop
    There may be a problem with the torque convertor and/or flex plate. I had a vibration problem on a car I built and finally got the vibration with the car sitting still. I replaced both but you can rotate the convertor in relation to the flex plate and see if that makes a difference. You have just installed a new engine and kept the old trans. Was the vibration present before you changed engines? Good luck !!
