Hot Rods Horsepower minimum, got a number?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 10, 2024.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    swade41 and Sharpone like this.
  2. 55Belairretrorod
    55Belairretrorod
    from Australia
    Some is good, more is better, too much is just about enough.
    Ned Ludd, Sharpone, loudbang and 2 others like this.
  3. Roothawg
    Roothawg
    There are a lot of folks out there with 500 hp 327’s. That actually equates out to a real world 250 hp.
    73RR, jimmy six, squirrel and 3 others like this.
  4. Roothawg
    Roothawg
    Ok, no math is allowed in my threads….that is too much like work.
  5. 19Eddy30
    19Eddy30
    from VA
    On a Spray !!!
    Average 327 with
    heads, 202
    cam, .460-.480
    intake single plane
    Would be 365 -385 crank
    & Knowing how to tune ,
    GlassThamesDoug and Sharpone like this.
  6. flynbrian48
    flynbrian48
    07C480A0-B5CD-49DA-9302-609664870099_1_201_a.jpeg 160 HP. I don't know what it weighs. I don't care
  7. aussie57wag
    aussie57wag
    from australia
    No minimum. The fastest car isn't necessarily the coolest. I can think of some model T gow jobs that I'd have over a supercharged LS powered modern street rod.
  8. bobss396
    bobss396
    My Ford is around 425 HP and the car weighs around #3500. Oh it moves pretty well for an old tank. If I go BBC in it, I'll shoot for north of 450 HP. At 500... the pucker factor starts creeping in.
    Sharpone and 427 sleeper like this.
  9. twenty8
    twenty8
    Don't think I said anything about "a waste" or "safe & practical"???
    Land speed runs and drag racing are what gets my blood pumping. Neither of these pursuits want wheelspin. Once traction is broken, maximum acceleration/velocity is over. For me, a burnout is only to heat the tires to get bite. More power is great, if it can be used for more than turning rubber into smoke. Acceleration is addictive.
    You might enjoy wheelspin, burnouts and loss of traction, and that's ok. Whatever tickles your pickle. It's just not for me.;)
    (If you like burnouts, do a search for Summernats burnout comp.)
    Ned Ludd and Sharpone like this.
  10. sunbeam
    sunbeam
    It's all a matter of car weight. Rember the Doug Nash Bronco 300 hp in a 2000 lb car and 600 hp in a 3800 lb car will get you about the same performants. PS and break less parts
    Sharpone likes this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Spending " money for nothing" pretty much ***umes " a waste" & also infers something other than safe & practical , no , you certainly like to argue about words , aye ? Why not explain precisely what you meant , sheesh !
    tomcat11, swade41 and 19Eddy30 like this.
  12. johnnymac1
    johnnymac1
    My thought is, depends on vehicle. My 300 hp 66 Corvette could have been a bit more, but my 34 pickup I built is tons of fun and drivability @ 275 to 300 horse.
    Sharpone and Hillbilly Werewolf like this.
  13. guthriesmith
    guthriesmith
    It all depends on the intent of the vehicle. A custom that is to look cool going down the road doesn’t need the same power as something that is intended to be a street brawler. So, somewhere between 85 and 800 or so seems about right to cover all that. :p
  14. Hillbilly Werewolf
    Hillbilly Werewolf
    I would drive that thing, even if I had to pedal!
  15. squirrel
    Or show me the MPH on a drag strip time slip.
    Sort of....but not quite. HP means you have to downshift to go fast. Torque means you just stomp the pedal, and you're instantly grinning
    chicken, 73RR, 427 sleeper and 2 others like this.
  16. bangngears
    bangngears
    from ofallon mo
    Way to much horsepower , is still not enough.:D
    427 sleeper and Sharpone like this.
  17. Sharpone
    Sharpone
    What he said
    Chavezk21 likes this.
  18. Well , here is where I can't run with the big dogs, for a lot of [$$$] reasons but will not stay on the porch! When I hopped up the straight eight in my 1950 BUICK I wanted a little more grunt. Which I got. The difference makes me grin when the throttle is opened, even a little, while driving. From 128 to MAYBE 200. Not dynode. Maybe this summer.
    Ben
  19. 34Phil
    34Phil
    When GM offered the cheap 190 HP 350 crate engine a lot of people here thought that was enough.
    bobss396 and Sharpone like this.
  20. pprather
    pprather
    It looks to me like the banger guys are having as much, and sometimes more, fun as the high horsepower guys.
    We all know that going down the highway requires very little horsepower.
    Sharpone, Ned Ludd and guthriesmith like this.
  21. mustangsix
    mustangsix
    Maybe I'm just getting old, but I really don't feel the need for 500hp on my daily drivers. It doesn't get me to work or the store any quicker and sometimes it's not much fun. I'm not racing anyone and we have a lot of traffic to deal with, too. I just can't use all that power and I'm not into ****-measuring contests or dyno-racing, so I'm happy with something tamer.
    For me the sweet spot seems to be right about 9-10lbs/hp, so for the little lightweight roadsters and MG's that we build, that's about 200-300 hp. That'll usually get me 0-60 in 6-7 seconds or less and at that power level the engines live long and get good mileage.
    BTW, the last autocross event I went to, there were a couple of 125hp Lotus Seven replicas absolutely kicking the *** of all the high power Mustangs and Corvettes. Those guys brought howitzers to a close quarter knife fight and got cut to bits......:cool:
    Sharpone, mohr hp and Ned Ludd like this.
  22. Jmountainjr
    Jmountainjr
    ***uming we are talking a street driven car, for me it's more that just the number. It's at what RPM you make the number. If it's not in a usable RPM range, it's a bit useless. An engine that pulls it's big numbers between 6200 and 7200 only gives you limited opportunity to use it on the street. I prefer an engine that has a broader power band at a more usable RPM that you can feel in the seat of your pants within reasonable abuse of the speed limit. The guys that mentioned torque are on topic. So something in the honest 375 to 400 HP in a 2800 lb. roadster / coupe.
  23. Mike Lawless
    Mike Lawless
    I left my need for speed on the track a few years back. I gave my street legal OT Karmann Ghia to my son at the beginning of 2019. Lbs per HP? 4. Yep , 4 at full boost. 142cu.in. 500hp, 2000 lbs. He's not licensed to run it fast as it will go at that power level, so the boost is turned down, so it runs low 10s. Maybe 350, or 375 thereabouts. On the street, it's a handful. Two handsful!
    My Ol Furd? Maybe 100-120 hp. Don't know. Hasn't even seen full throttle or north of 4000rpm since I built the motor. With my sedate driving style and the fact that it easily does legal freeway speeds while getting decent fuel mileage, it's all I need. These days, my measure of performance is how long it can go between fuel stops!
    Sharpone, 2OLD2FAST and guthriesmith like this.
  24. squirrel
    Yup...right up until you get to a hill.....
    Johnboy34, Sharpone and guthriesmith like this.
  25. RmK57
    RmK57
    That’s why I like my big block Fords, 557 cid with a stock block. Even with oem iron heads 550 hp and 600 lbs. torque is pretty easy and all at 5500 rpm.
  26. SS327
    SS327
    As much torque and horsepower as I can get! 600 hp and 578 ftlbs in a 3,000 lb daily driver was fun for me. But racing gas was cheap back then at only $5.00 a gallon.
    Yea, I’m not right.
  27. 56Packard
    56Packard
    from Phoenix AZ
    300-400 depending on the weight of the car And how much torque the engine has.
  28. goldmountain
    goldmountain
    I feel out of place in this discussion. I drive like a little old lady and don't need lots of power. As long as the car looks the part, I'm happy.
    CSPIDY likes this.
  29. swade41
    swade41
    from Buffalo,NY
    It was in a late 50's "little book" an adverti*****t for Champion spark plugs
    20201005_064456.jpg champion004001.jpg champion001.jpg champion002.jpg round2.jpg champion003.jpg champion004005.jpg
  30. 1971BB427
    1971BB427
    from Oregon
    Minimum HP for me depends on what car it's going into. What might be fast in my little Austin g***er is going to be a bit anemic for me in my heavy '39 Chev coupe.
    350 hp in a 2000-2500 lb. car is a lot of fun, but in a 3500 lb. car it's just okay, but leaves me wanting more.
    My 355 SBC in my Austin is around 375hp and turns low 8 second 1/8th mile times at 100 mph. My 355 full roller motor in my '39 is 435 hp, and slower than the Austin, but still quick enough to be plenty of fun.
