horsepower tricks for a cadillac 331?
Discussion in 'The Hokey Ass Message Board' started by hellspawn, May 5, 2009.
  1. hellspawn
    hellspawn
    from Wayne Pa
    I am looking for some tricks or changes to getting a little bit more rumble and horsepower out of a 54 cadillac 331 engine.....nothing major just a little more of a growl and some more pep in the engine
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Later heads are a bolt on, and (starting in '56) had larger ports; they got bigger yet in '59. Also, a later intake with a higher flowing AFB will bolt on in place of your current WCFB setup.
  3. The Brudwich
    The Brudwich
  4. hellspawn
    hellspawn
    from Wayne Pa
    thanks guys>>>so i can get later model caddy 390 heads and use them?
  5. The Brudwich
    The Brudwich
    Yep, but stay away from '63 390 engines. They're completely a different animal.
  6. r8odecay
    r8odecay
    I'm doing just that as we speak...(figuratively speaking). Been working on it about a year and going back together now.
  7. r8odecay
    r8odecay
    What is so different about 62??
  8. The Brudwich
    The Brudwich
    They're the later style engine with distributor in the front. They were bumped up to 429ci in '64 I think.
  9. r8odecay
    r8odecay
    63 only
  10. The Brudwich
    The Brudwich
    Oops! thanks for the correction
    I should have known better, I've worked two different 62's recently, but not engine work.
  11. hellspawn
    hellspawn
    from Wayne Pa
    what are the best year 390 heads to swap out? what other work would I have to do? any internals change with 390 heads on a 331 or does it just bolt up?
    also what are the best intakes to swap out onto the 331?
    sorry for the questions I am a motorcycle guy recently getting into cars
  12. hellspawn
    hellspawn
    from Wayne Pa
    also..any suggestions for exhaust? I want a nice rumble but nothing that will give me a headache on the highway
  13. r8odecay
    r8odecay
    Any of the 390 heads, (minus '63, thanks Brudwich) will be a vast improvement over the poor flowing 331 heads.
    Re-read the link Brudwich posted earlier from cadillacinmarcus, all the available and unobtainium intakes are on there. Heads just bolt up...of course make sure intake fits well, valve/rocker is indexed, ect ect...
