Technical Hose Clamp Clocking
Discussion in 'The Hokey Ass Message Board' started by blowby, Aug 12, 2015.
  1. timwhit
    timwhit
    You all are messed up, or maybe it's me.
    Model T1 likes this.
  2. 55Brodie
    55Brodie
    so that's why half of my switch plates are loose and the other half are broken. What a collosal waste of time. And I ain't buying the clean thing either.
  3. The37Kid
    The37Kid
    I think the acorn caps for the flathead head nuts were invented to cover the uneven number of exposed head stud threads. Few people can install head studs that all have the same finished height. Bob
  4. HOTRODPRIMER
    HOTRODPRIMER
    That's why I like to use ****on heads,no one critic them. :D HRP
  5. Slopok
    Slopok
    I always put my Phillips screws in an X pattern. Thought I was ****, I see I'm not alone.
  6. The37Kid
    The37Kid
    How about Bonneville guys, do they have their Dzuse fasteners at 9-3 o:clock for better air flow? Bob
    clem likes this.
  7. sunbeam
    sunbeam
    Clock them like the factory does so they are hard to get to.
    cretin and blowby like this.
  8. Dan Timberlake
    Dan Timberlake
    Heavy spot ain't necessarily the high spot, and it might help the tire runout to mount the tire high spot on wheel low spot.
    http://www.bridgestonetrucktires.com/publications/ra_v13_i1/PDF/ra_v13i1 ask doc.pdf
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=17
    http://www.continental-tyres.co.uk/...ervices_uk/resource_library/bulletin_1_en.pdf
    Unbalance can be compensated for with balance weights. Rinout can not.
  9. seb fontana
    seb fontana
    from ct
    I don't do the clocking thing as above posts but I know a few people I would like to "clock"...
    czuch az and Model T1 like this.
  10. Larry T
    Larry T
    Easy to space tie wraps evenly - finger length, hand length, what ever you want.
    I sometimes wipe the lettering off spark plug wires. Keeps the twists and bends looking even. But, everyone does that, right?
    Model T1 and Special Ed like this.
  11. Boy, I thought I was getting bad, because I put my tools away as often as once a week!
    Clock! I ain't got a clock, I'm retired!!!!!!!!!!!!!!!
    czuch az, Model T1 and Texas Webb like this.
  12. Personally I have always put the flat spot of the tire on the bottom. and always perpendicular to the Valve Stem ! It is really hard to achieve on a Traditional car with fender skirts.
  13. Hotrodmyk
    Hotrodmyk
    Thank you guys, I feel much better now. :D
  14. Bam.inc
    Bam.inc
    from KS
    OCD support group. I'm in.
    i.rant likes this.
  15. Rocky
    Rocky
    Classified Editor
    I feel better after reading this...I always clock the flats on my rocker arm nuts and sometimes late at night I take off the valve covers to make sure the nuts haven't turned....sometimes several times in the same night.....even if the engine hasn't run.... I really don't trust poly-locs....and I always put 4 periods at the end of each sentence....other than that I'm ok except for the checking to see if the door is really locked....43 times
    12 points are difficult to clock but I've mastered it....
    Model T1 and cosmo like this.
  16. fordor41
    fordor41
    I keep clocking my valve stems up but they keep changing as I drive!
    Kroombit and Model T1 like this.
  17. Tn. Trash
    Tn. Trash
    Everybody drank the kool-aid ?
    TagMan likes this.
  18. Tn. Trash
    Tn. Trash
    I thought about this, got dizzy and almost fell out of my chair.
  19. LowKat
    LowKat
    At my first NCRS Corvette judging in the early 80's the guy next to me is jacking up his car and turning each wheel, holding a up a little bubble level, then standing back and looking. I was more of a drag racer guy, so I'm asking myself WTF? Finally can't stand it anymore and ask him, he says "I'm indexing my hubcaps". I ask "did the factory do that?" ... no answer .. I knew right then the NCRS wasn't for me.
    Now I work on a collection of cars and that's "just how it's done" according to the **** owner. I do enjoy doing it for him but for myself I let it slide some. He has a pair of '31 Chrysler Imperials, so when ***embling those two cars, they also had to be clocked to each other.
  20. The37Kid
    The37Kid
    Do Flatheads go faster with indexed spark plugs? Bob
    Model T1 and 26 T Ford RPU like this.
  21. 26 T Ford RPU
    26 T Ford RPU
    I hate flat washers not having the rounded edge out, or at the least the same way.
    There are others, but that will do for now. :eek: :rolleyes: JW
  22. cretin
    cretin
    When I first started building cars, it's something I never even considered. But, as I started learning more and becoming more detail oriented, it's become important to me. It has happened where I see something that looks good, but clocking bothered me. Sometimes it can be over-looked, but as an example, when it's something that has a lot of slotted screws on it, it looks much better clocked. I pay attention to it, and do it on most things. It take very little time, but in my opinion, makes a big difference, and shows attention to detail. I think it speaks to how much you care about the design, but thats just one mans opinion.
    But here are two big pet peeves for me beyond that.
    One is wiring. Sanitary wiring makes a HUGE difference, and unsanitary wiring can make the nicest car look terrible.
    The other isn't really related, but I need to get it off my chest, haha.
    I can't stand it when I see a nice custom that has had a lot of work and attention to detail, and a nice interior with a period dash, and then they slap a modern head unit in the middle of the dash. Take some time and hide that thing!
    Model T1, Lone Star Mopar and Binger like this.
  23. 55Brodie
    55Brodie
    I'm beginning to see the light. Anybody know where I can get switch plate screw shims?
  24. Gary Addcox
    Gary Addcox
    This situation with BLOWBY begs the question, "Did he end up at Haight and Ashbury streets during the Summer of Love in '68 ?" Got to wonder.
  25. Gary Addcox
    Gary Addcox
    Torqueing is required. Clocking is not. Ryan just established a PARANORMAL section for all you guys so you can eat rainbow stew with a silver s**** and drink free bubble up.
  26. Gary Addcox
    Gary Addcox
    I have been told that a coil pointing down works better because the "juice", as electricity is sometimes called, more easily runs out to the distributor.
  27. LOST ANGEL
    LOST ANGEL
  28. Gary Addcox
    Gary Addcox
    Oh, no, you are not alone at all. There are many of you with "problems." Love that Merc. Is the lame job clocked?
  29. Gary Addcox
    Gary Addcox
    I heard about a large chemical spill several years ago in that immediate area. Now, I'm convinced.
  30. clem
    clem
    Some call it OCD , others say Perfectionist.
