Hot Rods Hot 283 SBC.
Discussion in 'The Hokey Ass Message Board' started by vetteson, Aug 3, 2020.
  1. vetteson
    vetteson
    I have a rebuilt 283, almost completely stock, recently installed in my '55 Studebaker Speedster. It runs hot, about 240 F in normal driving conditions. I thought at first it maybe was the gauge, a fairly new SW mechanical unit so I replaced it with a very little used electric SW gauge, same result. Then I noticed if I checked the temperature of the engine right after driving with a infra-red monitor (I used two different kinds), the temp. at the sender was around 200-210 F, The heads were about 215 but the radiator (a fairly new aluminum) was about 195 F. I am using a 14" puller electric fan. Anyway, I drained the system, ran a coolant flush, replaced the thermostat with a new 160 F unit, installed cooling fins near the radiator, new coolant with "Water Wetter" added. Same results with gauge (240) and infra-red temp. monitor (200+). I am told that the infra-red units are quite accurate. So why is the water temp. indicating 240 F?
  2. Gman0046
    Gman0046
    Not enough radiator.
    1927graham likes this.
  3. jaw22w
    jaw22w
    from Indiana
    I bought a cheap gauge set once. I believe it was Omega. Any way the temp gauge read about 30 degrees too high. I called customer support and told them the temp gauge reads 30 degrees too high. They said to put a resistor in the line to the sender. This has been a few years ago and I have CRS, but they told me what value of resistor to use to change the gauge 30 degrees , but I can't remember what it was. So it is possible to correct a gauge if it is off. Have you tried putting the sensor in boiling water?
    Blues4U likes this.
  4. Blues4U
    Blues4U
    from So Cal
    The temp gauge is immersed in and reading the temperature of the coolant; the infra-red gun is reading the temperature of the metal of the head, intake manifold or thermostat housing (wherever you measured it), that's not the same thing. The temperature of the metal may not be the same temp as the coolant.
  5. pprather
    pprather
    "Installed cooling fins near the radiator".
    Not sure what you mean.
    Phil
  6. Wanderlust
    Wanderlust
    What do your spark plugs look like, ie running too lean?
  7. vetteson
    vetteson
    Great feed back. Cooler plugs good suggestion. Cooling fins are inserts to otherwise heater hose, they do register a cooling effect with the monitors, the water temp. gauge reading 240 F is significant. If there is a differential between metal and water, then 240 F would be considered normal, but it isn't.
  8. putz
    putz
    from wisc.
    cross flow radiator ....
  9. Shutt
    Shutt
    Take cap off radiator with it running, make sure water pump is throwing water out the top and not spinning the wrong direction.
  10. swade41
    swade41
    from Buffalo,NY
    Is the sending unit in the head or in the intake ?
