Technical Hot 409s: Who has them or has built them in the past?
Discussion in 'Traditional Hot Rods' started by Mr. Sinister, Jun 8, 2011.
  1. 383deuce
    383deuce
    The true 409's were kick**** cars I alway thought. I have a 64 Impala true 409, 4 speed, all numbers matching, 51K orignal miles, one owner. That I would like to trade for a 32, 33 Ford. Any offers?
  2. bobwop
    bobwop
    from Arley, AL
    cast iron 409 with cast iron heads
    runs 10.4's on a good track
  3. BSL409
    BSL409
    Have steel block eddy heads all steel car body and the back seat in!!! Come to Thompson and Play May 31:D
  4. bobwop
    bobwop
    from Arley, AL
    can't make it
  5. Bullrack
    Bullrack
    from Louisiana
    LarryT, it is George Horton from Tenaha, I was half the night trying to remember that. He has, or I should say had, a pile of 409's! He had his "farm truck" in the 3/13 HRM Quick32 shootout. Anyway, it was one of those more memorable moments of life drooling over all those 409's, 396's, 427's, and tons of BBC's. Very friendly old country boy type of guy that didn't run me off with a shotgun and probably should've! LOL
  6. ROADSTER1927
    ROADSTER1927
    This is my 65 409 going in my 60 chev. It has 690 heads, ross 11 to 1 pistons, one notch below the z11 solid cam and now a M/T dual 4 crossram intake. Dripper valve covers, muncie 4 speed, 9'' rear/w/411 gears( torsion gleason center) watts link and dual control arms. Should be fun if the paint ever turns out and I get it back together! Gary:D
  7. BSL409
    BSL409
    Bruneau Performance Speed-Port Intake Dyno Results
    Discussion in 'Builds & Projects' started by CDNpontiac409guy, <A href="http://www.348-409.com/forum/index.php?threads/bruneau-performance-speed-port-intake-dyno-results.23328/"><ABBR class=DateTime****le="Apr 10, 2013 at 1:14 AM" jQuery1365670327875="2" data-time="1365570860" data-diff="99446" data-datestring="Apr 10, 2013" data-timestring="1:14 AM">Yesterday at 1:14 AM</ABBR>.
    <!-- main template -->
    Page 1 of 2 <NAV>1 2 Next > </NAV>
    <FORM class="InlineModForm section" action=index.php?inline-mod/post/switch method=post sizcache="0" sizset="13" data-cookieName="posts" data-controls="#InlineModControls" data-imodOptions="#ModerationSelect option">
    1. <!-- slot: message_user_info_avatar -->
      CDNpontiac409guy Supporting Member 5
      <!-- slot: message_user_info_text -->
      <ARTICLE>
      Well, we finally got through it today, April 9 2013. Complete dyno testing of three different intake manifolds.
      To re-cap, the engine used, was an all standard size 409, with factory forged pistons. The short block itself, was re-ringed in 2006... it IS a little tired, showing evidence of less than perfect ring seal[​IMG]. Ported "333" truck cylinder heads using 2.06" / 1.735" valves. Camshaft was from my own series, P/N M242595D. Headers were Belanger design, made by Wilson Header Manufacturing... 1 7/8" tube, 36" length, 3" collector, approx 16" long.
      Did a total of 13 "pulls". Same 750 CFM Quick Fuel carb. Timing ended up at 35 degrees total. Fuel used was basic pump premium, with a small dose of octane booster.
      The manifolds:
      Stock GM 340 HP 409 cast iron intake ( low rise dual plane )
      Edelbrock Performer RPM intake ( high rise dual plane )
      A Bruneau Peformance Speed-Port 6000 intake ( high rise single plane )
      In the photo I provide the link to, is the final graph, showing an overlay of the best "pull" with each manifold. Blue is torque, red is horsepower.
      dotted line is the stock intake
      broken line is the Performer intake
      solid line is the Speed-Port intake
      In a nutshell.... here are the basic peak numbers ( for extra info, I added some additional range on the horsepower figures ):
      Stock intake
      torque 438.5 @ 3500 RPM
      horsepower 389.9 @ 5400 RPM ( 387.7 @ 5300, 387.6 @ 5500, 385.6 @ 5600, 383.4 @ 5700 )
      torque 448.7 @ 4200 RPM
      horsepower 424.8 @ 5700 RPM ( 422.9 @ 5500, 424.3 @ 5600, 424.5 @ 5800, 423.9 @ 5900, 423.0 @ 6000, 421.8 @ 6100 )
      torque 466.6 @ 4200 RPM
      horsepower 465.8 @ 5800 RPM ( 464.8 @ 5600, 465.4 @ 5700, 465.7 5900, 465.7 @ 6000, 464.9 @ 6100, 464.4 @ 6200, 464.0 @ 6300 )
      The link to the graph:
      348 / 409 Chevrolet intake manifold dyno test comparisons
      What surprised me AND Dave at the dyno.... was that my intake did NOT give up torque at the lower end. From 3300 on ( where pulls were made from ), it dominated at all speeds.
      Been a long day... ​
      </ARTICLE>
    </FORM>
  8. 1moore
    1moore
    Here's ours
      136.1 KB
  9. 1moore
    1moore
    Some more
      145.1 KB
  10. vtwhead
    vtwhead
    FWIW....there is a fella over in NY state that is setting on a bunch of 409 stuff including 8 409 engines. I lined him up with the estate and he bought the eintire inventory from them of a racer from the 60's.
    Lots of performance specs for the 409's over on the 348-409 site. I believe this would be the go to site for all performance related subjects as those guys are building stroked 348's and 409 constantly.
    If you want the guys name over in NY I can look it up for you. Just send me a PM.
  11. Baumi
    Baumi
    Oh man... that was a great read!Now I want to build a 409....i should better avoid posts like this... Thanks for the Inspiration !
  12. BSL409
    BSL409
    Very Nice
  13. BSL409
    BSL409
    1962 Z11 409 Chevy from another sit
    <HR style="COLOR: #ffffff; BACKGROUND-COLOR: #ffffff" SIZE=1><!-- / icon and****le --><!-- message -->Just finished up a customers 1962 Z11 427 based off of a 409. Running LWA ported 1962 factory iron Z11 heads with****anium valves and 12.7:1 compression this little motor made 745 hp and 546 ft/lbs.
  14. bobwop
    bobwop
    from Arley, AL
  15. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Man, you guys are killing me!!! :D
  16. jcmarz
    jcmarz
    from Chino, Ca
    I'm savin' my pennies and I'm savin' my dimes:D
  17. captmullette
    captmullette
    lamar walden= 409
  18. BSL409
    BSL409
  19. jpnewlin
    jpnewlin
    Hard to imagine where we go from here!
  20. Larry T
    Larry T
  21. Hotdoggin DaddyO
    Hotdoggin DaddyO
    from Hays, Ks
    Mr. Bobwop
    I love your car.
  22. BSL409
    BSL409
  23. bobwop
    bobwop
    from Arley, AL
    thanks Hotdoggin
    that event at Thompson looks like a blast! busy weekend for sure
  24. pdq67
    pdq67
    I had a hopped up truck .060" over high compression w/ hand ground out big valves, NASCAR solid cammed, 348 tripped, (that I installed three big 2GC's on), 409 in my '67SS/RS Camaro on the stock 350 SS engine mounts years ago. 2,5" dia., cast-iron exhaust manifolds fit fine. I bought two '64 Imp. drivers side exhaust pipes and reversed the pass side 180 fine.
    As far as a 348/409 installing in a Tri-5, you should use the Tri-5 front mounts and it's side mount bell housing and you should be good to go!!
    And btw, a 348/409 use's a stock SBC fuel pump...
    Please come back and tell me if I'm fulla it???
    pdq67
  25. bobwop
    bobwop
    from Arley, AL
    as stated in the****le, this thread is about Hot 409's
  26. The machine work on these motors is a huge cost....be sure to get someone that knows what they are doing or you will be pouring huge $$ into big $$ parts with a result that you will not like.
    The cost of having a good set of cast heads worked (along with the core cost) is so that paying the $2000 for a set of Edelbrock 409 heads is something to consider.....I sold a set of cores for $650 and building them can cost $800+.
    I have around $12K in my 409 now but I think you can get into a nice 409 starting around $10K.
    These are not hi-rev engines but built for torque.......mine has 450 hp but 550 ft/lb of torque......plus they are just cool !
    Shaver Racing Engines offers 409 carb to pan and dyno tested for $10,500.....dont know much about them but is what Street Rodder put in their 55 tour car....I guess a free mill will get you good advertising !!!
  27. jcmarz
    jcmarz
    from Chino, Ca
    I have always liked the look of 348s/409s even though I have never owned one. But I can remember a time when they just weren't popular anymore. Car magazines used to refer to those prehistoric rats as boat anchors. In other words, they weren't worth the trouble.
  28. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    So level with me guys, with the money I'd sink into building an old school 409 (parts, machine work, etc), would I be better served just buying a crate engine? I know crate engines are a sin, but when it comes down to purely price, does it make sense? All new parts, versus throwing the dice on getting a sketchy block or heads, etc.
  29. Gene Boul
    Gene Boul
    I owned and raced (street) two 409's and one 348. Never had RPM problems or reliability issues. Was very capable street player in the 60's. As far as strip stuff famous AHRA kingpin (Del Blades) had the fastest "W" motor on the planet...at least it seemed to me. Just think about it...how fast do you want to go on the street? The 409 will be more than adequate...
  30. Larry T
    Larry T
    Depends on what you're gonna do with it and what crate motor you're gonna buy. You can buy a W crate motor now, but they aren't cheap.
    How about a Shafiroff 615 hp/509 ci street engine?
