Hot Alternator
Discussion in 'The Hokey Ass Message Board' started by MRod7007, Apr 3, 2012.
  1. MRod7007
    MRod7007
    Just hooked up a one wire alternator in a 1955 Chevy and it's getting hot....any thoughts?
  2. jusjay
    jusjay
    Did you ground it? Most if not all 1 wire alternator need to have a good ground.
  3. Fireant
    Fireant
    from Texas
  4. 61falcon
    61falcon
    is the battery any good? a weak battery will cause an alternator to overwork and get hot. resistance in the battey cables, is the ground cable at the block and chasis clean or is there paint causing a bad connection. is the alternator rated to handle the electrical load of the cars accesories. fan, ignition, etc.
  5. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    The alternator could be shorting out internally causing heat. I got a new one for my chevy and it was junk from the start. I blame junk chinese parts. :mad:
  6. Retro Jim
    Retro Jim
    If all the rest mentioned is OK , you might just have a bad alt . Just because they are new doesn't mean they are OK . You could have a bad alt. that just keeps overcharging and doesn't shut down . If that is the problem you could have cooked the battery too .
    Take it off and have it checked at the local parts store or where you bought it .
    Retro Jim
  7. Might be mounted to close to the engine..........
    Couldn't resist.
    I vote for a bad ground.
  8. wastedchilhood
    wastedchilhood
    Connect a volt meter to the out put on the back of the alt. It should read around 14.2 volts.If it reads down around 13 volts its charging at a high rate of amperage. Amps means heat think ark welder. If system voltage does not rise to 14+ volts after running for 15-20 minuets the battery may be bad.
  9. old soul
    old soul
    from oswego NY
    How do you ground it. Wouldent that make it a two wire???
  10. iammarvin
    iammarvin
    from Tulare, Ca
    Bolt it to the bracket that is bolted to the block? Just a thought.....
  11. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Bad grounds happen when you forget to scrape off the paint where the bracket meets the block, and at the alternator as well.
  12. retroridesbyrich
    retroridesbyrich
    from Central NC
    Went through a similar situation with one of those Power Gen units. Called manufacturer and they said tighten the belt more because it was slipping and it would cause that situation. I was skeptical, but did what they suggested and it solved the problem.
  13. Ebbsspeed
    Ebbsspeed
    How hot is it getting? They can get pretty warm and still be OK. Check the voltage at the output of the alternator, and also measure the voltage between the body of the alternator and the GROUND side of the battery. Any voltage reading there above a very small fraction of a volt will indicate a bad ground.
    I thought the ark was made of wood?
  14. boutlaw
    boutlaw
    Make sure the belt is proper for the pulleys being used. If the belt is running in the bottom of the pulley it will slip, oftentimes without any noise, and heat the pulley and the alternator to the point a diode can/will fail. A belt must run on the sidewall of the pulley, not down in the bottom of the groove.
  15. Grudge
    Grudge
    How much current is it putting out? Alternators are around 35% efficient, if it's charging at 80A x 14V that's 1.12kW, Which means its actually taking over 3kW of power, so a little less than 2kW is wasted heat. That's about 6800Btu/hr.
  16. Jimv
    Jimv
    They get hot! That's why they have cooling fins!LOL.
    Jimv
  17. henry's57bbwagon
    henry's57bbwagon
    My alt also gets too hot too touch, so my question is; what temp does the typical alt run at?
  18. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Pull the belt off and spin it. Bearings dragging? Won't always make a noise if bearings are dying.
  19. Ebbsspeed
    Ebbsspeed
    Some info I found on a non-traditional thread:
    In case anyone is curious about this issue, I came up with some temperature data:
    The owner of a 2001 Legacy told me that he measured his alternator at 220F with an infrared themometer.
    Another individual says that the maxium rated temperature is 239F.
    These units DO get hot, fast.
  20. stellar
    stellar
    They do get hot when running. If it is getting hot without the motor running, it is shorted and bad.
  21. 40FordGuy
    40FordGuy
    Ditto, the ground.... and ditto "stellar". I have one of the "generator" style alternators, from Speedway....Got hot as he** , so I added a heavy ground lead to the engine block, it runs a lot cooler now. Yes, they do tend to run on the "warm" side !
    4TTRUK
  22. 40FordGuy
    40FordGuy
    Use a heavy ground lead, from case to block.....Mine ran hot, the ground fixed that.
    4TTRUK
  23. dB Zac
    dB Zac
    I hate 1 wire alternators, since they are RPM excited there isn't much you can do about the heat besides checking your connections and making sure your wiring is up to snuff.
    Even a 3 wire alternator is really as simple as hooking up two wires. The field can be jumped off the battery lead and the exciter just needs to be tapped into an ign source (coil wire, AC comp wire, sometimes even the wiper motor has a ign switched 12 volt)
