Technical Hot as Oven 50 Ford
Discussion in 'Traditional Customs' started by Chop50, Jun 29, 2021.
  1. Chop50
    Chop50
    Hi All,
    My 50 is running driving on the road. Inside the car is hot as heck. No headliner and metal floors at this time which would probably account for a good portion of the heat. Vents are open..With the chop air seems to flow around it. How much can this be resolved, flathead 6 so AC is probably not an option..
    Thanks, Steve
  2. the oil soup
    the oil soup
    from Tucson,AZ
    lothiandon1940 likes this.
  3. lothiandon1940
    lothiandon1940
    Insulation.....and don't those vents come through the engine compartment?
    Tim and TrailerTrashToo like this.
  4. KevKo
    KevKo
    from Motown
    I plan on using the highly reflective metallic stuff like OEMs use on the outside of the firewall and under the floor by the trans and exhaust.
  5. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    Go to Home Depot or Lowe's and get some of the reflective bubble wrap looking insulation stuff and do the inside of your roof, it will make a huge difference. Get it up tight against the metal and use foil tape to secure it. I did this in an OT van and it made a world of difference. The stick on dynamat stuff (or similar product) works well on the floors and firewall.
    TrailerTrashToo likes this.
  6. atomickustom
    atomickustom
    And the roof. Lots of insulation everywhere, including the roof.
    Also consider heat shield between your exhaust and floor pan.
  7. atomickustom
    atomickustom
    ...and between the trunk and p***enger compartment. I was surprised how much heat was coming in from the trunk in my '53.
    In short, you cannot have too much insulation.
  8. 2935ford
    2935ford
    Hmmmmm.........winter is not to far off!!!!!!!! :) :(
  9. Tim
    Tim
    from KCMO
    Yup. Peel and seal that firewall a few times and the rest as well.
    lothiandon1940 and Guy Patterson like this.
  10. Casey Riley
    Casey Riley
    from Minnesota
    The fresh air vent could be bringing in hot air if there is a bad donut gasket between the blower motor and the the ductwork.
  11. Jalopy Joker
    Jalopy Joker
    post pics of interior, under hood, etc
  12. rockable
    rockable
    Seal up the firewall, shifter, brake pedal, etc. Hot air literally gets ****ed into the cab if there are open holes. Do this before you insulate but DO insulate.
    03GMCSonoma likes this.
  13. Insulation and carpet the whole firewall and floor on the inside top to bottom, front to back. It will stop 90% of it.
