Technical Hot Hard Start
Discussion in 'The Hokey Ass Message Board' started by iafraser39, Jun 2, 2014.
  1. carlos
    carlos
    from ohio
    Gerry Burger needs more influence on the magizine,he might be able to pull them outta their nose dive
  2. hidez57
    hidez57
    not recommended. I'm a nailhead lover, everything I've read say no.
    I have a nailhead powered 29 a,just on the road this week. same exact setup you have. brand new 750 edelbrock running ****py. mechanic friend popped the top off float level & drop were way off plus they have the leanest metering rods, went up one step richer. plus some of the jets weren't tight. runs like a champ now. this may not be your problem, then again.
    good luck
  3. slimpick
    slimpick
    Some guys will drill, tap, and plug the two exhaust holes.
    These engines originally came with a stainless steel plate under the carb. This is available at CARS and sold as a "carb baffle." I use this baffle on all of my nailhead engines. But, adding the phenolic spacer essentially does the same thing.
