Hot or cold rolled for sheetmetal?
Discussion in 'The Hokey Ass Message Board' started by chevman74, Aug 6, 2012.
  1. chevman74
    chevman74
    from Grahamvale
    Hey all am about to have a go with sheet metal repairs on my 59 Chev and am wondering if there is any advantage using hot or cold rolled sheet regarding the ease of manipulation and welding? Any input would be appreciated.
  2. pimpin paint
    pimpin paint
    from so cal
    orm
    Hey,
    Your best bet is gonna be the cold rolled material! Hor rolled isn't as smooth or uniform and doesn't bent or form like the cold rolled material.
  3. I don't think you will find 18 gauge sheet in hot rolled anyway.
  4. themoose
    themoose
    Here is a chart that shows whats available.
  5. bobss396
    bobss396
    Hot rolled is not as nice and clean as cold rolled is. Cold rolled can be picked up at Ace Hardware and other home centers in 2' square sheets and a little larger.
    Bob
  6. 19Fordy
    19Fordy
    Car body panels and stampings are made of cold rolled steel (CRS). Don't use HRS even if you find it somewhere.
  7. I'm pretty sure all of the thinner gauge sheet metal is cold rolled
  8. cayager
    cayager
    exactly.hot rolled in 1/8" and up
  9. 16 gauge is on the cusp. Most places will only carry cold rolled 16 gauge hot rolled is special order; 18 and thinner is cold rolled only. 14 gauge, most places only carry that & thicker in hot rolled. Cold rolled is special order.
    I once got a sheet of annealed 18 gauge by mistake - you could work it with a wooden s****. It would be great for really shapely pieces, but useless otherwise.
  10. 16 IS available in both HR and CR.....
    cold rolled steel is formable for panels /hot roll is ok for a flat smooth, floor section or such only.....you should grind off the flash where you weld the HR steel....
  11. chevman74
    chevman74
    from Grahamvale
    Thanks Bob, I think a couple of 8'X4' sheets may be necessary for the learning curve.;)
    Thanks for the advice choprods. I get a bit OCD about cleaning surfaces when welding, good welds come from good prep I say.
  12. There is what is called, Pickled Hot Roll. That means the scale has been removed. Hot roll is more plyable/bends easier. Pickled sheet metal welds clean. If you use easy grind welding rod or wire, faster clean up.
  13. Happydaze
    Happydaze
    I'd go a step further than that and say that you should be looking at removing the milscale from the entire surface, and not just where you are to weld. That black scale is a tough as anything but isn't suitable for painting over for a quiality, lasting finish.
    I say it's tough, it dulls sanding sanding discs very quickly but blasting gets rid of it in short order.
    By the time you've factored in the cleanup the premium paid for the cold rolled, or pickled, seems worthwhile. Opinions may vary.
    Chris
  14. bobss396
    bobss396
    Hot rolled also machines a lot better than cold rolled. Once you get through the bark, its nice stuff. I haven't done much with pickled stock, most of my experience is with larger structural shapes, tubing and big diameter rod. I had this one job I ran on the CNC lathe, a 70 lb blank that came out at 29 lbs when finished.
    Bob
  15. gatz
    gatz
    here's one source for sheet stock in various materials...
    Ryerson - Stock List
    Althoug a large company, Ryerson seems to be compe***ive in most areas.
  16. <TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD width=5></TD><TD id=content width=571>
    <!-- end pagepres.jsp -->Stocklist Home Sheet & Coil Hot Rolled Sheet <TABLE border=0 cellSpacing=0 cellPadding=0><TBODY><TR><TD vAlign=top colSpan=8 align=left></TD></TR><TR><TD></TD></TR><TR vAlign=top align=left><TD vAlign=top colSpan=8 align=left><!-- start headings --><TABLE id=content border=0 cellSpacing=0 cellPadding=0 bgColor=#f2f5f9><TBODY><TR><TD vAlign=top rowSpan=4 width=62 align=middle>[​IMG] </TD></TR><TR><TD><TABLE cellSpacing=6><TBODY><TR><TD cl***=stocklisttablehead1>SHEET</TD></TR><!-- BCOTE 10/18/2007 --><TR><TD cl***=stocklisttablehead2>Low Carbon Commercial Steel</TD></TR><TR><TD cl***=stocklisttablehead3>Hot Rolled and Pickled & Oiled
    ASTM A1011 CS Type B (A569 CQ)<SUP>1</SUP>
    RoHS Compliant
    </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE><!-- end headings --><!-- start sizes in stock --><!-- end sizes in stock --><!-- start rows --><!-- start column headings if no rows --><!-- start--><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width=550><TBODY><TR><TD cl***=stocklistcolhead align=middle>Gauge </TD><TD cl***=stocklistcolhead align=middle>Size
    in
    Inches
    </TD><TD cl***=stocklistcolhead align=middle>Decimal
    in
    Inches
    </TD><TD cl***=stocklistcolhead align=middle>Est.
    Wt. per
    Sq. Ft.
    in Lbs.
    Wt. per
    Sheet
    in Lbs.
    </TD><TD cl***=stocklistcolhead align=middle>CS-B
    Low
    Carbon
    Pickled
    & Oiled
    </TD><TD></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>7</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>36 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>180.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>36 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>225.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>36 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>270.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>48 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>240.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>48 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>300.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>48 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>360.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>60 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>300.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>60 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>375.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>60 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>450.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>60 x 168 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>525.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>72 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>360.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>72 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>450.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>72 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>540.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>72 x 240 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>837.2 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>84 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>525.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><!-- start 1--><TR><TD cl***=stocklistcolhead align=middle>Gauge </TD><TD cl***=stocklistcolhead align=middle>Size
    in
    Inches
    in
    Inches
    Wt. per
    Sq. Ft.
    in Lbs.
    Wt. per
    Sheet
    in Lbs.
    Low
    Carbon
    Pickled
    & Oiled
    </TD><TD></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>96 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1793 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>7.500 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>600.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>8</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>36 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1644 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>6.875 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>206.3 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>48 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1644 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>6.875 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>220.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>48 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1644 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>6.875 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>275.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>48 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1644 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>6.875 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>305.5 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>60 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1644 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>6.875 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>343.8 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>72 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1644 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>6.875 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>412.5 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>10</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>36 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>135.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>36 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>168.8 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>48 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>180.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>48 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>225.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>48 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>270.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>48 x 240 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>450.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>60 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>225.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>60 x 120 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>281.3 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><!-- start 1--><TR><TD cl***=stocklistcolhead align=middle>Gauge </TD><TD cl***=stocklistcolhead align=middle>Size
    in
    Inches
    in
    Inches
    Wt. per
    Sq. Ft.
    in Lbs.
    Wt. per
    Sheet
    in Lbs.
    Low
    Carbon
    Pickled
    & Oiled
    </TD><TD></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>60 x 144 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>337.5 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>60 x 168 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>393.8 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>60 x 240 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>562.5 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR><TR bgColor=#ffffff><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>60 x 306 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff width="70%" align=right>717.2 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle>X</TD></TR></TBODY></TABLE><TD bgColor=#ffffff align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR></TBODY></TABLE><TD cl***=stocklisttablecontent bgColor=#ffffff align=middle></TD></TR><TR bgColor=#d1e4f0><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle></TD></TR></TBODY></TABLE><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>72 x 96 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>.1345 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>5.625 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 width="70%" align=right>270.0 </TD><TD></TD></TR></TBODY></TABLE></TD><TD bgColor=#d1e4f0 align=middle><TABLE id=content border=0 cellSpacing=0 cellPadding=0 width="100%" clear="both"><TBODY><TR><TD cl***=stocklisttablecontent bgColor=#d1e4f0 align=middle>X</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
  17. Mr48chev
    It is far beyond expensive when you buy it that way though.
    It's far better to find a steel supply of fabrication shop that will sell remnants. We have one local s**** metal dealer who will sell you sheet metal pieces by the pound. Pick what you want, put it on the scales and pay and go.
  18. 38Chevy454
    38Chevy454
    Hot rolled is usually pickled and oiled. The pickle means acid dipped to get the scale off, oiled for corrosiion protection. It is usually only avail in 16 ga or thicker, and 16 is on the edge for availability.
    Just get the cold rolled, it has the best surface finish and is clean. There are numerous grades of cold rolled as far as formability, but that is a whole different discussion. All car sheetmetal is cold rolled, some thicker material like frames or crossmembers can be either CR or HR.
  19. bobss396
    bobss396
    If you got someone local, great. I have a place like that and sometimes he says, just take it. They do a big shearing service and the floor abounds with the drop offs.
    Bob
  20. chevman74
    chevman74
    from Grahamvale
    Good point Chris, be easier to descale flat stock than a finished piece once your happy with the shape or have curves that are harder to get at.
