Hot Rod Horns...
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jan 12, 2011.
  1. thunderbirdesq
    thunderbirdesq
    Open wheel guys, what kind of horns are you running on your cars? looking for ideas... Old bike horns, stockers? I bought this old deco EA one on Epay and while I think it's absolutely gorgeous, I didn't realize just how big it was until it arrived on my doorstep. 7" in diameter... Unfortunately, I think it demands a little too much space to be used on my car. Wish it was about 5"...
      33.8 KB
  2. That's a pretty SOB for a visible horn. Hid mine under the p***enger side floorboard and attached to the crossmember under the front of Model A seats. HId them because they ain't pretty, but you can hear them when they work like a 72 Caprice dual horn.
    Worthless w/o pics here on me.
  3. sawbuck
    sawbuck
    from 06492 ct
    i use an old harley horn, repop ... i think it was 5 inch.got it on ebay
  4. Slick Willy
    Slick Willy
    I mounted mine to the grille shell mount. The horn is a tiny (@3") cheapy motorcycle horn (like 12 bucks) and has a little bracket that I just bent to a 90 deg. It does stand out if you are looking.. I may paint it black to make it disappear.
  5. Saxon
    Saxon
    from MN
    I think I put 1 bid on that exact horn! I'm going with a ahooga horn under the p***enger floor board. Cut up an old late 30's brake light & license plate bracket to make a bracket for the horn. Still need to wire it in, started on the repo harness today.
  6. Saxon
    Saxon
    from MN
    That deco is a great looking horn.
  7. 32 Barn Car
    32 Barn Car
    from Oregon
    Mine....It's a 1930's 5" Schwarz motorcycle horn , looks about right to me .
  8. flthd31
    flthd31
    Couldn't find anything that looked cool so I stuck one of these on the ****** crossmember...works ok under there.
  9. Look at Motovox and Bosch as well- plus there were all the early motorcycle horns!!!
  10. fleetside66
    fleetside66
    Same here..the pic's a little dark, but you get the idea. The horn works great. Here's what I've been doing...when I built the car, I just just hooked up some very generic stuff (horn, tailights, steering wheel, air cleaner, etc.) & then when something special comes along, I buy it & replace the generic piece. So far, I've replaced the air cleaner & steering wheel, but I'm still searching for the right tailights & horn. That 7" job is nice...hmmm...
  11. cavemag
    cavemag
    I'm planning on running a roadrunner horn.
  12. HuffDaddy
    HuffDaddy
    I put a reproduction 12 volt '48 Harley Davidson springer horn on my roadster. I mounted it to the firewall on the p***enger side near the bottom.
  13. Frenchy Dehoux
    Frenchy Dehoux
    Is necessary to have a relay or just a fuse. And what size fuse to use.
    Frenchy
  14. mr.chevrolet
    mr.chevrolet
    what about this one?
  15. My guess is it's from a boat?
  16. larry woods
    larry woods
    from venice fl
    used a repro aaoogah on my 32 chevy. bolted to frame under drivers seat. figure if they can't hear the rumble need a "noise" to wake them!
  17. octobeak
    octobeak
    I like the aaoogah, but on an open wheel you have to get creative with mounting
  18. thunderbirdesq
    thunderbirdesq
    I was hoping to do this with the EA or maybe mount it on the firewall, but at 7" I think it will just be visually distracting. It would probably look great on a firetruck... :rolleyes: I think I'll hunt down an early bike horn of some sort. Trying to stay away from repop stuff for this car. Any other ideas?
  19. beauishere
    beauishere
    I always liked the two-tone sound of the horns on my '57 Chevy, so I'm putting them in the 'legs' of the K member on our '32.
  20. They're visible and they're loud.
  21. bgaro
    bgaro
    u shouldn't need a relay, maybe 15 amp fuse. old harley davidson is the way to go the older the better. i am using a freebe 1968 hidden under floor
  22. 49ratfink
    49ratfink
    I just use my middle finger
  23. Da Tinman
    Da Tinman
    ford ranger horns, cheap easy to find, plenty loud. Paint em flat black and mount them low so they kinda disappear
    (yeah I changed the pic)
  24. Merlin
    Merlin
    from Inman, SC
    I have a couple small autozone specials in the same place as Tinman.^
  25. Da Tinman
    Da Tinman
    the wifes falcon got these LOL...
    I like a loud horn, specially on a quiet car. Nothing like watching someone come unhinged when you sneak up on them from behind and lay into the horns.
  26. steel rebel
    steel rebel
    I really have to watch myself so I don't junk up the roadster. I debated a long time before mounting the little horn but I think it kinda adds something.
    Now looking again I'm not sure. What do you think?
  27. krylon32
    krylon32
    from Nebraska
    I been using a HD Springer horn on the cars we build. They are designed to hang out front on the scooter so they should hold up under a coupe or roadster!
  28. Steves32
    Steves32
    from So Cal
    I hid my horn under the car just to piss off Groucho ;)
  29. cadman89
    cadman89
    Mine doubles as a front bumper :)
    Cadman
  30. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Use a Honda Shadow horn - about 3 in in diam and has a plastic chrome cover
