Hot Rod Horns...
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jan 12, 2011.
  1. hotrd32
    hotrd32
    from WA
    '58 Packard.... mounted under the car
  2. LIL.TIMMYUser Name
    LIL.TIMMYUser Name
    I think it looks pretty sharp:) certainly not out of place or overwhelming at all.
  3. Russ B
    Russ B
    no room for a stock horn on the '29 A pickup once I installed the dropped headlight bar this summer.
    I tried to mount the stock ah-ooga horn below the seat, but no room there either, so I found a cheapo plastic, china-made 'aooga' horn on Amazon for about $10 that was smaller and fit underneath. It works and is apparently only worth what I paid, so I expect it will not last too long.
    ... but now all that is barely showing is a generic flush mount horn ****on that I painted and mounted in a new bracket under the dash.
    ...and I can't even find a finished pic of it cleared and mounted.
  4. steel rebel
    steel rebel
    Thanks. Your not just being nice are you?
  5. Merlin
    Merlin
    from Inman, SC
    That just looks funny IMO.:eek::D
  6. shmoozo
    shmoozo
    from Media, PA
    What are you using for an air supply?
    Or did they come with a small compressor?
  7. burnout2614
    burnout2614
    Aoogah! and yes, after moving it twice, it's always in the way. I have an old siren but we all know how ANNOYING they are! peace
  8. Bruce Lancaster
    Bruce Lancaster
    Firewall mount was a common solution on rods, but looks like you have a '32 shell. How about bracketing it to the inner lower apron right behind the grill? It would be an interesting nearly hidden detail, and only a portion would be up in actual air flow.
  9. 5window
    5window
    I used a chrome ahooga and mounted it outbnoard of the frame rail on my '31 A without hood sides.
  10. tommy
    tommy
  11. junk yard kid
    junk yard kid
    I wish i had photos. I took a old broken model a ahooga horn, i cut the motor out of it, then i welded the flange to the motor houseing. Then i took a new plastic ahooga horn and cut a bunch off the horn bit and stuffed it in the housing from behind. Ran the wires and screwed the back cap and front metal horn on. Now it looks old but has a 10 buck horn in it. Better than 200 for a new repo one. Oh and it sounds good too. I mounted it from the shock mount holes on my model a.
  12. thunderbirdesq
    thunderbirdesq
    AAAAHAHAHAhahaha!
  13. Bull
    Bull
  14. Don Lyon
    Don Lyon
    Horns are for Bulls,if your brakes give out just scream really loud and look for something really cheap to run into.:eek:
  15. junk yard kid
    junk yard kid
    I got a toyota without a horn. When i need to honk, i stick my head out the window and yell HONK! as loud as i can. The looks i get.....
  16. steel rebel
    steel rebel
  17. thunderbirdesq
    thunderbirdesq
  18. thunderbirdesq
    thunderbirdesq
    I think I solved my conundrum... That EA is just too big for my car and I think a little too fancy as well. I want a nice looking, cool horn, but I don't want it to be the first thing people notice about the car. I just bought this one and at a little over 4" it should be perfect to mount on the firewall and not attract too much attention. Thanks for the input, fellas!
      49.7 KB
  19. flynbrian48
    flynbrian48
    Thank God you didn't do this...
    Brian
  20. thunderbirdesq
    thunderbirdesq
    No worries Brian, hahaha! :D
  21. moefuzz
    moefuzz
    I think it has a certain "Hooter" look to it:D
  22. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    an 80's caddy horn-sounds like a freight train
  23. moefuzz
    moefuzz
    I have one of those 7" motorcycle horns the same as your EA.
    Does anybody know what these came of off or were they aftermarket???
  24. RustyNCA
    RustyNCA
    Running an old Wolf Whistle mounted on the manifold. It takes practice to make it do a wolf whistle.
  25. [​IMG]
    Any more info on this one- I LIKE it!
  26. thunderbirdesq
    thunderbirdesq
    It just says Electro-Horn (MC) 6V 0.8A 110P Model MG. Check out the size difference!
      279.1 KB
  27. kwmpa
    kwmpa
    from Pa
    too bad you foun one i have a 40s indian motorcycle one i woulda given you
  28. kwmpa,
    I'd be interested if you still have it for sale!
  29. kwmpa
    kwmpa
    from Pa
    Not really for sale andys a fellow club brother....just doing what I can so his car is ready for the detroit autorama
  30. thunderbirdesq
    thunderbirdesq
    too bad I found one, you crack me up! :D this little guy looks great on the firewall.
