Art & Inspiration Hot rod parts you would like to see produced.
Discussion in 'The Hokey Ass Message Board' started by 55willys, Nov 27, 2016.
  1. robracer1
    robracer1
    This may sound off the wall, but a reproduction looking 55-57 Thunderbird Y block aluminum finned w/t bird emblem in center valve cover that will bolt on my 302 sbf. Always thought that is the best looking valve cover ever made, I think it would look cool on my 32 Roadster with side hoods off!
    BigDTexasKid likes this.
  2. That would tighten the knot up, but still a big knot on top of the column under the wheel.
    The Nissan unit puts the knot under the dash. Depends on the application what would be better.
  3. Smokin Joe
    Smokin Joe
    Better Corvette valve covers so all the ***holes can pawn off their dead 305s as all origional 365 horse 327's to the street rod crowd.
  4. dos zetas
    dos zetas
    Curvey, heavy, cast aluminum headers for flatheads that clear the steering box on the common A and 32 frame applications, there'd be a market.
    BigDTexasKid and LOU WELLS like this.
  5. hotroddon
    hotroddon
    Doesn't United Pacific now offer those?
    http://www.hotrod.com/articles/1212cct-cl***ic-y-block-covers/
    robracer1 likes this.
  6. BamaMav
    BamaMav
    from Berry, AL
    Front disc brake kit for 46-48 Lincolns with Ford 5x4.5 bolt pattern.
  7. A Boner
    A Boner
    YES.....I'll buy a set!
  8. falcongeorge
    falcongeorge
    from BC
    For the 305 guys...:rolleyes::D The only guys you'll be fooling without the $400+ intake, solid lifters, 461's and big balancer are the rodabillies here on the HAMB.
    https://www.paragoncorvette.com/p-350402-aluminum-valve-cover.aspx
    Minus the post-67 casting flaw...get your wallet out, that's $155 EACH.
  9. DDDenny
    And four points of compression!
  10. New Jeep shifters that fit the Top Loader 4 speeds, I've always had to buy used and they are usually worn out. Not aware of anyone making these and are out production through CJD.
    56don likes this.
  11. Standard32
    Standard32
    from LA
    Hub caps with the correct old style "domed" profile.
    Squablow, lewk, Just Gary and 3 others like this.
  12. falcongeorge
    falcongeorge
    from BC
    DAMN STRAIGHT!!
    LOU WELLS, Just Gary and lurker mick like this.
  13. banjorear
    banjorear
    Love everyone of your ideas!
  14. Alaska Jim
    Alaska Jim
  15. Blue One
    Blue One
    from Alberta
    They didn't have black at the time, they may now.
    They sent me a sample that was pretty black ...... 1028479-5R555 Charcoal Pleated Vinyl Sample.
  16. PoRodder
    PoRodder
    from St. Louis
    Stamped rear quarter panels for 26-27 Ford roadster trunks. As far as I know, they have to be hand made if you want new.
    falcongeorge likes this.
  17. 55willys
    55willys
    If I have one as a sample even a worn out one I can have them cast. There is the rest of the shift rail parts and the stick itself to make
  18. Just Gary
    Just Gary
    BF Goodrich Sport Truck T/A radials in the "big weenie" sizes like 315-70/15 and 345-55/16.
    Ned Ludd and loudbang like this.
  19. For sure !!!!
    I wonder if we get enough committed that they would run some ? There's a market but it's small.
    Just Gary likes this.
  20. 56sedandelivery
    56sedandelivery
    Real chrome reverse wheels, and NOT the smoothie kind; the kind with 3 or 4 bumps to hold hub caps on. I know, a couple of the wheel guys offer them, but it takes a while to get them, and they are $$$$$. I'm not greedy; that's all for me. I am Butch/56sedandelivery.
    Alaska Jim and loudbang like this.
  21. JROD_31Hiboy
    JROD_31Hiboy
    I would like to see someone remake some of the overhead valve's of the 50's. Nailhead's, Hemi's, Y-Blocks, maybe even some Small Block chevy's with 283 CI.
  22. Erwin
    Erwin
  23. Not to rain on your parade-
    There's more than enough of those out there to rebuild. A bit more of the necessities for those rebuilds would help. But if you want one they are there.
    When one guy talks about rebuilding building a 283 there's 1000 guys tell him to get a treefiddy. Then when he talks about building a 350 they tell him get a crate treefiddy.
    The hemi, y block and nail heads cost more to rebuild and then they pile on with the crate engines again.
    williebill, loudbang and 55willys like this.
  24. With a smooth dished face, like an authentic flipped Buick rim.
    brandon and lurker mick like this.
  25. lewk
    lewk
    from Mt
    I was going to ask for the same. Also, how about 35-36 3 window garnish moldings, and 35-36 coupe trunk lid structure patch panels?
  26. DDDenny
    Right on, really think BFG f'd up on this deal.
    Those big by huge ones are perfect for hiboys.
    This would actually trump my two previous posts.
    Problem is; I've really gotten attached to my Firestones, no matter how bad they are for street driving.
  27. Mo rust
    Mo rust
    Reproduce the single bar flipper hubcap that uses a separate trim ring. They used to be made by National. I've been looking for one to replace a lost cap on my fathers 36 roadster for six months and there aren't any to be found.
    Squablow likes this.
  28. woodbutcher
    woodbutcher
    :D Hi Blue1.Most likely reason that you did`nt find black on that site is that you would`nt like to sit down on a boat seat after it soaked up heat for a while and burn your buns clear back to your hip bones.Or blister yourself real good.
    Good luck.Have fun.Be safe.
    Leo
  29. grapeboy
    grapeboy
    Steel front fenders for 49-51 Fords
  30. bob b.
    bob b.
    from peoria az.
    41 ford center and side grill
