Hot Rods Hot Rod Works or Speedway
Discussion in 'The Hokey Ass Message Board' started by butch27, Mar 24, 2010.
  1. butch27
    butch27
    Thinking of buying a 6 spline open-drive conversion kit for a banjo rear. Anyone know of any differences (beside the price) of these 2 companies kits?
  2. TERPU
    TERPU
    No choice buy the Hot Rod Works one. Hot Rod Works guys are cl*** act.
    Tim
  3. The Brudwich
    The Brudwich
    Ditto, Hot Rod Works hands down!
  4. WaldenSpeed
    WaldenSpeed
    from Pomona CA
    Hot Rod Works made in USA
    Speedway copy of Hotrod Works made in China
  5. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    Hot Rod Works. They make a great product and are super guys to boot!
  6. The Hot Rod Works is the real thing. Everything they make is first cl***.
  7. krylon32
    krylon32
    from Nebraska
    Use the Hot Rod Works. Reports have it that the Speedway copy has some unadjustable freeplay in it when installed.
  8. AV8Paul
    AV8Paul
    HOT ROD WORKS!! They invented it and speedway copied it.
  9. butch27
    butch27
    Thanks: That satisfied my morbid curiosity . LOL
  10. JOECOOL
    JOECOOL
    I don't know how much work you want to do,but I made my own and it really wasn't hard. I did have some pic's and were posted here but I think they are long gone.I purchased a yoke from NAPA ,I think it fit a Ford 4x4 front transfer case.I then used the original enclosed driveline housing,went to the bearing store and crossed a seal with an O.D the size of the inside of the housing and an I.D. to fit the yoke. The yoke does not bolt on so it will slide in and out ,so I drilled two opposite holes where the seal misses and put two set screws. It went about 10,000 miles and was still working great when I sold it. Hope this helps.
  11. hotcoupe
    hotcoupe
    friends don`t let friends buy from Speedway!
  12. Hack Attack
    Hack Attack
    I just picked up a Hot Rod Works kit....very quality stuff.
    I wouldn't hesitate to buy from them again.
  13. butch27
    butch27
    Joe: I was thinking about that but the machining work ( boring the yoke and the tube for a seal race is very expensive here in the "Motor City".
  14. 117harv
    117harv
    It fit a ford transfer case, what....you can't just say that and not give the year or appl. your killing me LOL.
  15. KIRK!
    KIRK!
    I like both companies, but Hot Rod Works did create the part, then it was knocked off. Hot Rod Works just did a 9" conversion for the Legion Special and their work is stellar.
    Also, I have one of their open drive conversions on there too and the quality is flawless. Couldn't have been easier to install or fit better.
  16. scootermcrad
    scootermcrad
    Hot Rod Works was great to do business with! You can't go wrong with them! They are also HAMBers.
  17. hotrod40coupe
    hotrod40coupe
    Easy choice, HOT ROD WORKS, a cl*** act.
  18. seventhirteen
    seventhirteen
    from dago, ca
    he cross referenced the bearing with the yoke and housing size, it could almost be any yoke......
    hot rod works made it first, makes it better and last i checked it was even cheaper than speedway, not much to think about, buy hot rod works
  19. 392_hemi
    392_hemi
    Another vote for Hot Rod Works. I would not trust the quality of anything Speedway sells as their own.
  20. krooser
    krooser
    Hot Rod Works... Speedways Chi-Com unit has too much slop in the tolerances from what I've been told.
    Even Chinese Hot Rodders buy American....
  21. mike hamel
    mike hamel
    I have never had them do anything else for be beside quickchanges but after my friends and I, I think we have sent them close to 6-7 V8 quickchanges and they come back completely finshed with the highest quaility work. I would recommend them with 2 thumbs up. You will get great service with those guys, they are very friendly and will treat you well. Hope everything works out for you.
  22. thunderbirdesq
    thunderbirdesq
    We have used the hot rod works kit. Great piece, works perfect, installs easily.
  23. I think you have your answer but just in case I'd say Hot Rod Works, never had any problems with there stuff and Ken and Nick are great guys to deal with.
  24. tobyflh
    tobyflh
    from Peru il
    i'll get **** for this but who is hot rod works and do they have a web sight?
  25. butch27
    butch27
    Oh: About the yoke, It's doesn't really matter cause you bore it out anyway if you're making your own.
  26. Blown Mopar
    Blown Mopar
    from abc
  27. JOECOOL
    JOECOOL
    Actually I didn't bore out the yoke.It fit the spline ,the splined shaft on the rear was too long and i sawed it off , the yoke then slid back to the nut on the splines. I took the original cover ,drilled the bolts out slightly and installed it so I could let it self center on the seal surface.Neither the yoke or the housing were remachined or bored out.
  28. 40Tudor
    40Tudor
    from MN
    All right, Joe, we're gonna need a part number or application or SOMEthing on this yoke. ;-)
  29. butch27
    butch27
    Yes JOE: Post soon cause these things cost a lot of money. Thanks
  30. scrap metal 48
    scrap metal 48
    Bought mine from "Speedway"... Fit great, works great.............
