Hot Rodding the 144 Ford 6
Discussion in 'The Hokey Ass Message Board' started by Chaz, Nov 26, 2006.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Was that the one where two guys were shoehorning a 312 into it?
  2. Ghostrdr
    Ghostrdr
    from Missouri
    Put a hundredHP shot of nitrous on it and drive it til it blows up. Then upgrade to the 200 and go nuts.
  3. chuckspeed
    chuckspeed
    Chaz -
    Haring and Flyin' eye are on the mark. The 144 usedta be the engine used by hydroplane racers in the 60's and 70's for cl*** racin' - a super, super, well tuned 144 would make 200 HP on alcohol and Hilborn injectors. The engine wouldn't last a season; the combination of the long crank and five main bearings meant that crank whip would crack the crank and render the engine a hot lump of cast iron in no time flat.
    the 200 is a seven main bearing engine; everything (damn near) bolts on and the motor makes great torque and decent HP outta the box. The hot ticket is to add a cam, mill the intake to accept thee 1 bbl carbs, and add a header - you'll be knockin' on 200 HP.
    I had a '64 Falcon with the 170 and the two speed - I got beat in a stoplight drag by a diesel eldorado on 1980. Diesel Eldos took 17 seconds to get to 60 MPH. A 144 Falcon with a two-speed auto is like tattoing with a rusty needle, IMHO.
  4. tjm73
    tjm73
    Spending money on a 144 is like flushing money down the toilet.
    Please don't compare small displacement early hemi's and flatheads and such to the turd that is the 144. ditch it and do a 200 or bigger engine if you have your heart set on an I6.
    www.fordsix.com (I think) is close to releasing a serious aluminum head and intake for the 200/250. I believe early simulations put a 250 I6 at around 300-325 crank hp.
  5. junkmonger
    junkmonger
    If you're gonna take the time to swap motors, go with the 250. There are hopup parts available, and you've got cubic inches on your side.
  6. Do an internet search for "the ford falcon six cylinder handbook" Its an excellent book, and they have an entire chapter devoted to exactly how big of a pain in the *** it is to put a 250 in an early Falcon. Those who believe it is a bolt in just because its the same engine family are wrong. I've seen it done, its not easy. Theres so much work required you might as well put a 289 in it.
  7. Chili Phil
    Chili Phil
    Go ahead and run that 144. Be sure to go to your local tractor supply and get one of them orange triangles to bolt to the trunk.
    Seriously, the 144 is slower than the smell leaving cat ****.
    270dodge and acjcf2 like this.
  8. junkmonger
    junkmonger
    Isn't the 250 the same block as the 200? Maybe I'm mistaken in thinking it's a shoe-in.
    All I know is it worked great in my old Fairlane (which has about twice as much space in the engine compartment). All I did was weld up some tri-y headers and use a 1 to 2 bbl carb adapter. It would have worked even better with a different intake and a hot cam.:D
  9. Chaz
    Chaz
    I know I'm gonna cause a ****storm here, but my idea is to take the 144 and make the best of it. Are there better engines to work with? Hell yeah
    Everyone can see building up a flathead, but a logical move would be to replace it with a SBC... A built flatty will never be as dependable or run as strong as a comparable small block... Flatheads are something we just love and we overlook and compensate for their shortcomings.
    I'm caught up in the potential of this small displacemet ford six. surely theres someone else out there that is interested as well. I've already found some cams and carbs, and I think I can modify the intake thanks to some of the postings here...Sooooo.... Keep the comments coming. Good and bad
    I'm interested in it all.
    If it was about a swap, I'd put in a damn 289.....
  10. One problem with it is the fact that you really won't want to rev it much, with those skinny, skinny rods, & lack of breathing. Unfortunately, it has an extremely short stroke, which would lend itself to revving in order to make some power.
    I can understand your thought process...it's the thrill of the chase, so to speak...would it be a possibility, if you don't want to change the engine...to at least change the crank, etc. & make a 170? Call it "stroking the engine" rather than "swapping the motor".
  11. Dick Dake
    Dick Dake
    Flatheads were well designed for their time. Still reliable and able to make at least 200hp without blowing. The 200 was also a good mill. The 241 Hemi was good but small and has a cool foctor to it. You can also get reasonable performance out of it without getting stupid. The 144 just ****s. besides, you can probably find a good 200 cheap from a guy putting in a SBF in an old 'stang.
  12. Chaz
    Chaz
    Homespun, Correct me if I'm wrong here,(and I usually am) but wouldn't a longer stroke make it MORE prone to come apart? I was thinking about leaving the stroke short and boring for larger pistons.
  13. Derek Mitchell
    Derek Mitchell
    Chaz, I say go for it!!!!!!!!
    I'm pumpin up the 170 in my 62 Falcon, when and if it blows, then I'll look into a 200, but until then the 170 is it.
    I thought I had that cover pic saved, but can't find it now.
  14. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    I got a small turbo if you think you can incorporate it into that (6) cylinder
  15.
  16. Chaz
    Chaz
    Hmmmm.. Lets see.
    The Ford flathead when introduced( 221 ci/65hp ) produced .29 horsepower per cubic inch.
    At is best , in 53 (336ci/ 152 hp) it produced .45 horsepower per cubic inch
    The 60 Ford Falcon (144ci/85hp) produced .59 horsepower per cubic inch.
    The crankshaft isnt even centered in a flatty.
    A lot of folks are telling me a 144 aint worth the effort and its a real dog.Yet the guy at the s****yard can get sky high prices for flattys and I beam axles cause "that rat rod crowd will pay big money for those"
    I understand the allure of a flathead but lets get real - They're no great shakes either. It all comes down to what you like.
  17. haring
    haring
    The only reason these engines on the cover are 144s is because the 200 hadn't been invented yet. :) The image showing the y-block being lowered into a Falcon is from one of the "spotlite" hot rod books (I think ... I don't own that one).
    Chaz, don't use the 144. If you do, I'll have to ***ume you also whip yourself and eat dog food.
    volvobrynk likes this.
  18. haring
    haring
    Not saying you can't hot rod the Ford small six, just use the 200.
    I bought one COMPLETE, with TOPLOADER ******, that RAN, for $100 from a Mustang guy. :D
    Ak Miller slingshot:
    An image I grabbed from the Internets. I think it was for sale at the Pomono swap meet, or something like that...
  19. Mike
    Mike
    The 144/170/200 family of engines aren't worth much, even good running ones are pretty much give away engines. The 200s are not hard to find. I have good runner in my yard that was given to me with a good C4 trans attached. I know where there is annother good running 200 and C4 nearby that I can also have for free, all I'd have to do is go and pick it up.
    I would recommend against hopping up the 144 not because it is slow, but because the bottom end is super weak. Even just enough revs to get decent freeway speed will likely cause the 144 to ****ter in short time, then you'll be looking for another engine to swap anyhow. Avoid some greif, find a 200 to swap in and hop that up.
    Tanoki likes this.
  20. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That's true....so after 99 per cent of the posters on this thread have told you NOT to bother with the 144, and to go find a 200 instead, if you try to hop up the 144 anyway, "don't come crying to me" (to quote one of my father's familiar quotations from my childhood).
  21. Chaz,
    The 144 & 170 use the same block, so "strokin'" it (the engine, dammit! :D ) at least won't cause any more problems than already exist. You would, however, need the 170 rods, & I believe the pistons are different as well, or at least they have a different skirt design. Not sure on the compression heights. Dunno if you want to spend that kind of coin if it runs OK now.
    Try headers, new valve springs, recurving the distributor, & maybe some intake/carb improvements & see where you go...not too much $$ lost if something catastrophic does happen.
  22. tjm73
    tjm73
    Don't take this the wrong way but..... those numbers ellude to efficency in stock form and are pretty much worthless in this context.
  23. usmc50lx
    usmc50lx
    from St.Louis
    damn wish i could find my pictures in high school in 2003 I had a 170 in a '65 falcon 4dr. Anyway a milled 200ci head and a homemade header,also built a adapter to run a rochester 2gc on the stock intake.With the three on the tree it was some fun and quite the sleeper with the stock aircleaner on it honda boys had no idea. Wasn't the fastest at school but was fun and would kill the ricer crowd.
  24. 61falconwagon
    61falconwagon
  25. Chaz
    Chaz
    Sorry guys but this one wont leave my head...
    Now to show you how stupid my thought process is , I'm thinking..
    A racing challenge for 144 /170 ci ford sixes, The engines are cheap, and since speed parts are rare, homebuilt modificaions would RULE !
    It'd be fun to watch because **** would be blowing up all over the place!
    Blow it up? Go get another giveaway engine.
    Kinda like a HAGR , but the cost would stay within everyones range,
    I gotta get more sleep..............
  26. 61falconwagon
    61falconwagon
    I'll bring the sun dial to time them :O) I drove a comet with a 144/automatic it was very poky. But ran great. My 61 falcon with a 170/3speed is a speed demon compared to that comet.
    look at this big pile of............performance
  27. mustangsix
    mustangsix
    Y'all know that this could get ugly!
    The engine in my Locost roadster is a modified 200 (aluminum, canted valve, Cleveland-style, Aussie head) and estimated hp is around 225.
    The engine in my 66 Mustang is a 250 with a similar head, but with EFI, a hotter cam, and more porting. HP here is over 250, but with gobs of torque.
    and over the years myself and the guys at FordSix.coom have ffigured out LOTS of ways to make a 200 really scream!:eek:
  28. Merc63
    Merc63
    And a Cox .049 R/C model plane engine makes over 450 hp per liter. But would you power a full size car with it? it's easy to make more hp per cubic inch with a smaller engine by it's very nature. But you've reached the point of diminishing returns with even the stock 144.
    Do what you like. You're gonna find that the "swap" to a 200 is effectively what you're attempting to do with the 144, but with more money, time, effort spent and in the end, still using a 144 weak crank and rods. The moment you pull the 144 out to mod it, you're doing more work than to bolt in a stock 200, all for less return. Thrill of teh chase may be a good reason for a lot of things, but this is just financial and logistical silliness for no actual benefit.
  29. Ghostrdr
    Ghostrdr
    from Missouri
    The EFI six needs a Turbo and then it should be entered into a drifting contest to show the littlle effers out there that American cars are the instigators of the original brodie racing style.
  30. Junkyard Jan
    Junkyard Jan
    Mark me as at least one person interested. Hot Rodding has traditionally been based on doing stuff differently than the next guy. You're building the 144 for all of the right reasons....'cause you want to, and I can't think of a better one. Keep me apprised on how things go.
    I'm working on an old style 223 Ford 6 in a 3400 lb car. Talk about lack of performance potential...:D Am I doing it because it's "nostalgic" or that someone else thinks it's cool, **** no! My curiousity simply got the better of me and I want to see what I can do to improve this old mill. I realize that a 223 will likely never blow off a stock 350 Chevy 4bbl..unless someone pulls half of the Chev's plug wires, but I'm having a bunch of fun figuring out ways to boost the stock 145 horses to 170 or more. So I say GO FOR IT!
    BTW, the 144 was successfully raced in midgets during the mid '60s, so finding an old circle burner who raced one might be of some help. You might be able to find somebody at fordsix.com
    Jan
