HOT TIP, Budget hotrod gas tanks
Discussion in 'The Hokey Ass Message Board' started by Tman, Apr 8, 2004.
  1. Here is a link to some budget poly tanks. Since we seem to be budget minded (cheap) *******s. www.overtons.com
    They have tanks for around $100 WITH Stewart Warner senders!A pal ordered on, it is nice quality. There are several shapes and sizes to choose from
  2. bobbleed
    bobbleed
    from Awesome
    I found that using those portable air tanks for a gas tank works well. They are super cheap and I think they come in 7 and 10 gallons. They look pretty good too. You just need to add a fill hole and seal them.
  3. Jaker
    Jaker
    I just got a 10 gallon portable air tank for $35. It's going to work kick *** for a gas tank. Of course after I started welding and cutting on it I found one at Auto Zone for like $19 bucks.
  4. du$ty
    du$ty
    i also i run a 10 gallon (like the hat) [​IMG]air tank for my gas tank.welded a filler neck...used the pressure gauge hole for my gas line hookup.works good.
  5. Jaker
    Jaker
    Hey kartbreaker- got any pics of how you mounted yours?? I too am building a 27 roadster (with a y-block)
    your car is pretty neat
  6. du$ty
    du$ty
    ill look around ....i might have some picts..nothing too it just makde some floor bracing in the decklid area and laid the tank in.and on the other side made a floor piece.is your a true roadster?i hate my car.it makes me mad.i want a coupe or f100.who wants to trade [​IMG] [​IMG]
  7. Nimrod
    Nimrod
    I ordered this 20 gal. aluminum tank with sender out of a marine suppyly catolog a couple of years ago for about $130. Fit great behind the seat in my model A, just had to spread the braces out about a half inch. I used the filler cap from the moon tank up on the daisy panel. The tank is a little wider on top than the bottom...I guess to fit along the side of a boat hull.
  8. Nimrod, I have an Aluminum boat tank that I bet was produced by the same people! I paind 100 bucks for mine.
    The rest of you are REALLY cheap [​IMG]
  9. Plowboy
    Plowboy
    I got mine from Cabela's for around a hundred. Works good so far.
  10. We made or own tank, cost us around 14 bucks(tank sealer) with out the fuel pump.... Oh and its 14 gallon [​IMG]
    steve-
