Hotrod Insulation
Discussion in 'The Hokey Ass Message Board' started by leonxpipeman, Oct 10, 2013.
  1. I would like to know the opinion out there is regards to the peel & stick sound deadening and radiant heat insulation, using asphalt based and or butyl rubber based with aluminum foil cover. Does anyone have any experience using these products. I have had samples sent to me from ZillMat, Dynamat, GTMAT, HushMat, FatMat and Eastwood. Which one out there seems to work the best. I want to insulate the complete interior surfaces of my 1950 Ford Shoebox Coupe including the trunk area and if anyone has used the asphalt based materials, does it give off any odor or does the aluminum foil conceal it.
  2. Christom
    Christom
    I put it all through the interior of my AV8 coupe - just to kill a bit of the "sitting in a steel drum" kinda sound. Didn't do the unlined upper (roof) portions - just the lower areas - doors, trunk sides and floor etc. I just used some cheap no-name stuff sold off the roll locally - Chinese made I'd guess - like everything else these days.
    Worked well I think - doors no longer sound tinny when closing - doesn't smell or anything.
    Just let it sit in the warm sun before installing so it's more workable and roll it down with a small roller.
  3. 40FordGuy
    40FordGuy
    I keep hearing "DynoMat",...but also that it's on the pricey side. There was a thread some time back, about using a "peel n stick" roof repair material, available from Lowe's.
    The person posting said it worked great. Anyone ?
    4TTRUK
  4. 117harv
    117harv
  5. brad chevy
    brad chevy
    I used the stuff from Lowes on a 1961 pickup works great,and didn"t spend a fortune. If you have plenty of money go with the dynamat but just buying a namebrand doesn"t always make it a better product.
  6. I know its not peel and stick, but Lizard Skin is pretty impressive. Both for sound and temp.
  7. 40StudeDude
    40StudeDude
    Lizardskin by far is the best, I've built five cars so far and used it in every car...you can see it being shot here: http://www.jalopyjournal.com/forum/showthread.php?t=785551&highlight=the+2nd+best+60+chevy
    IF your shoebox is in the build stages, use the Lizardskin...if it's not, it's going to take a lot of masking paper/tape to keep the rest of the car clean when spraying Lizardskin as it goes all over using the gun they recommend/sell.
    I've used some peel and stick stuff over the top of the Lizardskin in the build above...it's called Cool It Thermo Tec Suppressor (sticky one side, foil the other and you can see it in the build) and once it's down, it ain't coming back up...!!! I don't know at this point if it smells in the sun since the build isn't done...but I wanted the wagon very quiet and insulated to the max that's why I went with both...I also used Lobucrod's insulation in the roof...and he swears by its insulating properties...
    R-
  8. bgaro
    bgaro
    search peel and seal on the hamb.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    There is a HUGE discussion here with pictures etc:http://www.jalopyjournal.com/forum/showthread.php?t=711889 also here is an update on mine post #289 no smell :) see my earlier post regarding the seam tape that is a must.Here is the info on seam tape post# 169 http://www.jalopyjournal.com/forum/showthread.php?p=9192456#post9192456
  10. Bill Wright
    Bill Wright
    I used the bituathane roofing material. Didn't get it from Lowe's. ABC Roofing supply.
    The trade name is Grace (Manufacturer) Ice and Water shield.
    It works very well and any out g***ing disappears very rapidly.A roll runs around $100.00 but that's enough to do a couple cars!
  11. themoose
    themoose
    Check with your local RV dealer.They usually carry a large selection of sound deadening and thermo barrier materials.
  12. baspinall
    baspinall
    from SE PA
    I used Dynamat on a Nomad I had and it was great stuff. Got a really good deal on Ebay. The only reason I used it. It's a bit overpriced.
  13. okiedokie
    okiedokie
    from Ok
    I agree with Lizard Skin (used it on my 40) but as far as foil backed tar stuff ( I used B-quiet on the 40 over the LIzard Skin) I will not use it next time. I think that Lobucrods stuff over the Liz Skin is the way to go. I posted some testing I did a couple of years ago on all three, but not sure I can find it. I am away from home using an IPad and not sure I can find the post. Try searching for "more on insulation" if you care to look.
  14. NATESBPD
    NATESBPD
    I just used dynamat..but heard lizard skin works good too.. I'm happy with the dynamat extreme though
  15. telecaster_6
    telecaster_6
    I used the peel and seal that is advertised at lowes...though i couldnt actually get it from there in the 36" wide roll. They couldnt even get it delivered to the store, so i found it online. Stuff works great and is super cheap compared to dynomat or comparibles. Seems to really help with both heat and noise.
  16. 40FordGuy
    40FordGuy
    Thanks........ Time for a trip to Lowe's.
    4TTRUK
  17. 325w
    325w
    Lobucrods insulation works good. I used loc***e adhesive in a chalking tube and stuck to the roof. Very easy to do.
  18. okiedokie
    okiedokie
    from Ok
    Lobucrods still around?
  19. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
  20. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    This is me too. Use this one for company stuff and the other one for BS
  21. chickenridgerods
    chickenridgerods
    from DSM, IA
    Ideally, you'd use two different types of products to help reduce interior sound. A m*** layer such as the rubberized peel-n-stick type products to reduce low-frequency noise, and a layer such as the foam or fiber products to reduce higher-frequency noise.
    I've used the RAAMmat BXT and Ensolite products from RAAMmat.com with good results. The Dynomat is bit overpriced for what you get; Dynomat does have a great marketing department, though.
  22. dan31
    dan31
    I bought Dyna mat for my 31 ($$$) and realized it's the same stuff I used to use in the valleys and eves in my old roofing days. When I do my 54 I will go this route and save some bucks.
  23. Leviman
    Leviman
    I'll say I've used the 'quick roof' as it was called to do my beetle and it seems to work well. Although the webers still make a lot of noise, but I ain't complainin' :D
  24. sidevalve8ba
    sidevalve8ba
    I used Eastwood's version. It is considerably cheaper than DynaMat. It worked well in my '32 pickup cab. I'm happy with it.
  25. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    My 57 was done with pro stuff, I believer fat mat. The shop that finished out the car got it for me and I rolled it in. Dad's A built 30 years ago we sprayed the interior with undercoat, layered roofing tar paper on it, then another coat of undercoat. Funny to watch all the guys thump it and swear its a gl*** car.
    It was cheap and it worked in the days before store shelves had it.
    My unibody has a combination. Sprayed everything with undercoat, then used peel n seal on it. The firewall and roof also got a covering of Reflectix, also from the hardware store. Its like foil backed bubble wrap. Does a real good job keeping heat out. Now if I just had weatherstripping and maybe AC in the uni it'd be a nice quiet cool highway drive...
  26. lcfman
    lcfman
    from tn
    That Lowe's stuff is not even close to being as good as dynamat even though the dynamat is not cheap. You get what you pay for.
