Projects HotRod Rebuild
Discussion in 'Traditional Hot Rods' started by ModelARon, Mar 18, 2021.
  1. Shaun1162
    Shaun1162
    Just went through this whole thread, love this coupe!! You’re doing this car a lot of good, and maintaining a lot of its character
  2. ModelARon
    ModelARon
    Thanks . I am having a great time bringing this car back to life.
  3. dart4forte
    dart4forte
    from Mesa, AZ
    looks like you got it covered. One thing about is it can be changed if you have a problem. Here, in sunny Phoenix my tank vents when pressure builds up on hot days. My vent comes out in one of the stake pockets.
    Real good job of resurrecting and old rod.
  4. ModelARon
    ModelARon
    I finished the floor pans i just need to paint them. I plan on screwing them down into the existing subrail so i can remove them if i need to fix something. I will use some seam sealer and put the plywood on top of the sheetmetal . This way it its flush with the subrail. IMG_5461.jpeg 66709488850__1070D541-6CFE-4266-B73D-ED9735A72F72.jpeg
  5. ModelARon
    ModelARon
    I was installing the dash but it was too tight so i had to do some grinding too get the parts to fit.
    I thought i had a good fit two years ago before i painted them. I will just have to respray them. IMG_5459.jpeg
  6. ModelARon
    ModelARon
    This hood came with the car when i picked up the car. Any one know what it is from?
    I am considering using the two top sections for this build. I will need to make some adjustments to make it fit. Someone has made some mods to improve air flow within the engine compartment. IMG_5472.jpeg IMG_5473.jpeg IMG_5468.jpeg IMG_5470.jpeg
    Tman, chryslerfan55, Stogy and 2 others like this.
  7. Mart
    Mart
    I don't know what it is from but I had a 30's Austin with those catches. Or rather if those catches have "Ripaults" on them they are the same as on Austins and probably others.
    Stogy likes this.
  8. ModelARon
    ModelARon
    The hood is still a mystery. The letters on the catch are TENAXIT and it has a patent #.
  9. ModelARon
    ModelARon
    I decided to install the sound system . I built a ported subwoofer box to fit behind the seat.
    Had some nice weather so i took the old Vette out.
  10. ModelARon
    ModelARon
    I installed the USB port in the seat frame so i can control the system.
    I kept the system out of sight. IMG_5657.jpeg IMG_5659.jpeg IMG_5658.jpeg IMG_5661.jpeg
  11. AHotRod
    AHotRod
    Awesome job!
    Stogy likes this.
  12. indyjps
    indyjps
    Great car, Great build. Very nice paint work. Keep the updates coming.
    Cragars came out in about 1964, what wheels did Frank run when the car was first built ? I like the Cragars, just curious.
    Try some Murphys oil soap on the interior panels, very mild soap but does a lot for leather, vinyl, pleather to keep it soft.
    Cutting gaskets, I keep little straps of pipe around with different diameters, sharpen the edge, punch them out. Works for cork or rubber sheet.
  13. ModelARon
    ModelARon
    Frank had some Keystones on the car about 1965. I love the rear wheels with the pie crust.
    Thanks for the tips. The s**** pipes would have helped to make the gaskets.
    IMG_5666.jpeg IMG_5667.jpeg I will apply some type of soap to help soften the interior.
    Vic Walter and Stogy like this.
  14. ModelARon
    ModelARon
    Stogy and Tim like this.
  15. dart4forte
    dart4forte
    from Mesa, AZ
  16. dart4forte
    dart4forte
    from Mesa, AZ
    Years ago I attend an all British Field meet in Portland, OR. All types of British cars were in attendance. Some of the old Brit cars from the 30, had those knobs holding down the bonnets of their cars. Did remember until I saw your pic. Someone slong the way thought it was a cool part to put on your hotrod.
    Stogy likes this.
  17. ModelARon
    ModelARon
    good info. thanks
    Stogy likes this.
  18. ModelARon
    ModelARon
    Here is the progress in the last two weeks. I installed some sound deadening material . I repainted the two interior parts that needed some grinding to get them to fit. The last picture is the light bar i wear when i need extra light they work great.
    I also use it when i paint so i don't miss anything IMG_5675.jpeg 67009721103__DA279AD9-E3F0-4A64-A9D1-ADA4A6A444BB.jpeg IMG_5741.jpeg IMG_5734.jpeg
  19. ModelARon
    ModelARon
    Today i installed one of the doors. I used the paint stand to hold the door in place .
    This way i can hang the doors solo. IMG_5766.jpeg IMG_5765.jpeg IMG_5769.jpeg IMG_5770.jpeg IMG_5771.jpeg
  20. Tim
    Tim
    from KCMO
    Looking good!
    Stogy likes this.
  21. Mart
    Mart
    Wow. The car is looking great! Excellent work going on here.
    Stogy likes this.
  22. SS327
    SS327
    Damn! That is one good looking vehicle! That’s one Ford I would be proud to ride in! Love the roof insert and running boards.
    Stogy likes this.
  23. jim32
    jim32
    Love the double needle s***ch on the seats.
    osage orange likes this.
  24. ModelARon
    ModelARon
    The inside door panel is rubbing on the door jam so i removed the fabric from the panel .
    I will trim the board at the red line and shift the fabric enough to clear the door jam. IMG_5784.jpeg IMG_5800.jpeg
  25. Super Streak
    Super Streak
    from Florida
    Great job, like the way you tried to keep it as the original builder put it together. I also own a small block Ford powered '30 model A coupe. Enjoy driving the car as much as possible.
  26. 409 John
    409 John
    Great work here and an inspiration too!
  27. ModelARon
    ModelARon
    This weekend i set the toe-in to 3/16", thanks to the info i found on The hamb it was easy.
    I was under the car looking for issues that might need adjusting or leaks. Found some paint worn on the front crossmember. The tie rod rubs on the crossmember when turning the car. I moved the tie rod to the second hole in the spindle arm. I had to ream the hole out to get the ball joint to fit. That
    fixed the problem.
  28. ModelARon
    ModelARon
    I was planning to hang the driver side door but found a water mark in the paint.
    I will not buff out. Its in between the clear coats. Must have missed that.
    It is only visible at certain angles. I will sand the lower section of the door and shoot two coats of color and a few coats of clear.
    I think when i cleaned the doors to shoot the second round of clear i missed it. IMG_5878.jpeg
  29. ModelARon
    ModelARon
  30. ModelARon
    ModelARon
