Hotrod rolling chassis
Discussion in 'Parts For Sale' started by tys0n88, May 15, 2020.
  1. tys0n88
    tys0n88
    City: Pinckneyville
    State: Illinois
    Price: 5500
    Reilly automotive frame, 4” sweep in front, 8” Z in rear. It has about 104" wheel base.
    Pete & jakes ladder bar set up, posies super slide spring, Pete & jakes rod shocks, plus all brackets & shackles, set up for small block Chevy or LS
    Superbell 4” drop axle, custom split wishbones, posies super slide front spring, Pete & jakes rod shocks, p&j’s pan hard bar, spindles, brake caliper mounts, pest & jake disc brake kit, cross steering setup, Vega box
    8.8 ford axle out of mustang, fresh built with new internals, posi, fresh drum brakes, welded tubes to housing.
    6.0 liter LS block, still has crank in it & appears to be in good shape, 318 heads. Motor needs cleaned & built. I have a lot of parts that came with the engine. Has adjustable LS swap mounts to make it fit SBC frame mounts.
    The rear axle brackets are tacked on where they should be needs fully welded. I am building a different ch***is for my car so this one has to go. Everything besides motor & axle are brand new. Willing to take a loss to get it out of my way.
    Local pick up only can meet within reasonable distance.
    lo c dan likes this.
