House Of Kolor Thinner For Epoxy??????
Discussion in 'The Hokey Ass Message Board' started by angry, May 18, 2006.
  1. angry
    angry
    from ventura ca
    What Do You Thin The Epoxy With
    After I Put In The Activater Its Still Way To Thick
  2. lownslow
    lownslow
    i use ru311 . it is a mid temp. which epoxy are you using ?....
  3. 67Imp.Wagon
    67Imp.Wagon
    If its PPG's DP primers I use the DT885
  4. dirtbag01
    dirtbag01
    from dallas
    im really liking sikkens its some bad ass paint and ive used just about all the rest
  5. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    HOK used to have a dedicated reducer for it's epoxy primer (I think it is EP-3). They have discontinued it, but I like it better than their new recommendation. Now they say that their regular RU series of reducers will work, like lownslow said. I like the EP-3 better becuase you need to clean the gun afterwards with the same reducer you use in the primer, lacquer thinner doesn't do it well. The old EP-3 really cleaned it out good, the RU-311 doesn't do as good a job.
    See if anyone's got any EP-3 laying around!
  6. angry
    angry
    from ventura ca
    thanks for, the reply
