Projects How about a 53 Chevy Hardtop build !!??
Discussion in 'The Hokey Ass Message Board' started by Leebo!, Feb 4, 2013.
  1. Leebo!
    Leebo!
    from Yale OK
    Seriously though, I thought there were not enough build threads of these model of cars, :D , so I thought I would upload mine as I go along.
    A little history on this, I bought it roughly 8 or 10 years ago when I was going through a divorce, and getting together with my current wife. I bought a sedan and a HT as a package deal. The sedan was in MUCH nicer shape, and I thought SURELY i could sell off the HT and recoup some of my money. Tried selling it on ebay, and only got an $80.00 bid.Put it on here to trade, and didnt get offered much that interested me. Eventually I drug it to my parents place, where it has sat on thier farm housing rodents, while I have moved about a half dozen times for work.
    Fast forward to February of 2011, and I decide I like the HT roof lines better, and im going to build the HT.
    Here is what she looked like when I bought her.
  2. Leebo!
    Leebo!
    from Yale OK
    So after nearly a decade of sitting, she makes the 4 hr trailer ride from SE Oklahoma, to NW Arkansas. Thinking its a bonus that it is already subframed with a nova frontend, I later discover the hillbillies who did it couldnt read a tape measure, and had the wheelbase an extra inch and a half to long. So out comes the sawzall to remedy that situation.
  3. Leebo!
    Leebo!
    from Yale OK
    I no sooner get her lined up, and tacked back together, and my welder takes a crap. :mad:
    And I get tranferred the same day, back to Oklahoma, AGAIN :rolleyes:
    So loaded her up once more
  4. Leebo!
    Leebo!
    from Yale OK
    The last decade sitting in a field hasnt been kind to her. Add in the mountains of rat/raccoon and various other varmint piss and crap in the floorboards, and my floors are toast. First order of business was floor panel repair.
  5. Not only a hardtop but a 210 hard top
  6. Moedog07
    Moedog07
    I love those the 52-53 Chevy's good luck with it. What's the plans for the engine / transmission?
  7. Leebo!
    Leebo!
    from Yale OK
    After that, I pulled the body so i could start the fun on the frame. I had decided I would run a 2 link (from a 60 something chevy p/u) with a panhard, but didnt have all the details worked out in my head yet. I installed a Walton Fab trans crossmember, mainly because I didnt have any original reference points on teh frame due to the nova sub.
    After that, I installed a Gambino notch, and a 69 camaro rear end scored off craigslist.
  8. 54LedSled
    54LedSled
    Cool Build...Suscribed!
  9. Leebo!
    Leebo!
    from Yale OK
    The 2 link crossmember caused some hiccups for me. My original plan was to build a new one out of tubing, similar to some I had seen on here. I tried a few different variations, and none seem to work to my liking, sooooo... I went back to modifying the original, which turned out to be just as time consuming. If i had it all to do over, I would make a pattern and have the machine shop cut me nice one. Live and learn i guess. You can see from the pics how much adding/sectioning it took to make the thing look like it belongs.
    Cut the top half off, and used it to widen the sides:
    Added some 1/4 angle to the top:
    More shots of the various cuts/welds:
    Finally kinda resembles what I was wanting:
    Added some reinforced exhaust ports, and it should work
    Even momma got in on the action on this project!
  10. DAVEO!
    DAVEO!
    Hell yeah!!!! i dig it! gonna keep an eye on this one :D
  11. Leebo!
    Leebo!
    from Yale OK
    A couple pics of my frame coming together. Ended up using RE8 airbags, modifying a panhard kit from suicide doors, and made some brackets to mount shocks to 2 link.
    Finished before sandblasting. You can see I also gusseted the frame where the it was subbed. Might be overkill, but i dont want any doubts:eek:
  12. Leebo!
    Leebo!
    from Yale OK
    Some more pics of after sandblasting-painting- re assembling the frame
    Donor 305 (for now)
    Clearanced the frame on top, and made it a "plate mount" on the lower A-arm.
  13. Leebo!
    Leebo!
    from Yale OK
    Oh yeah, Got lucky that after I re-did the subframe, I was able to use stock motor mounts bolted in with NO modification. That was a shocker!!
  14. Leebo!
    Leebo!
    from Yale OK
    So it was time to cut out some of the floor
    And re-join the 2 halves
  15. Leebo!
    Leebo!
    from Yale OK
    And then I started building the driveshaft tunnel
    And decided the rear "feet pans" were junk, so......
    And wouldnt you know, my tires rub the wheel wells
  16. Leebo!
    Leebo!
    from Yale OK
    And wouldnt you know(of course) I decide the rear seat pans need it too
  17. Convert54
    Convert54
    from Oklahoma
    great little thread for the 210.
    The extra cross bracing you are putting in is greast as the original fram had a stiffening beam down the center of the frame rails to keep the doors from poping open.
    Looks real good from what I can tell.
    Notice your without a good rear window.......those are few and far between.
  18. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    where did you get the trailer fenders for the new rear fenders. ( or maybe they are some aftermarket fenders for something else)
  19. Leebo!
    Leebo!
    from Yale OK
    Convert- Luckily I found a glass in Lincoln NE, last weekend, as well as the 210 rear spear i stupidly traded years ago.
    Boones- bought the fenders at northern tool. Had to widen them 2 inches, make the panels on both outer sides, and legthen them on the each edge. Still much easier than using the stock ones and trying to stretch them!
  20. rat nasty
    rat nasty
    kool deal right here! I suscribed!
  21. Johnnee D.
    Johnnee D.
    wow, nice build, subscribed...keep up the good work
  22. fnla39
    fnla39
    Subscribed. Working a '53 myself. Liking the rear suspension set-up.
  23. Leebo!
    Leebo!
    from Yale OK
    I never really put much thought into the 210 HT part. If my research is correct, they only made 15 thousand in this series. Someone else on one of my earlier threads pegged this as a VERY early 53 HT, as it had some floor braces that werent used in 53, only up to 52 :confused:
  24. SwedeVedette
    SwedeVedette
    Man youre doing some great work, will follow this thread..
  25. Suicide-D
    Suicide-D
    from Texas
    Nice job on the crossmember. This all looks so familiar. Oh yeah. I think I have a project very similar. I wonder where I left that thing?
  26. Leebo!
    Leebo!
    from Yale OK
    Thats funny, I think I messaged you about 50 times on the subject, and actually had your build saved as a reference!
  27. Leebo!
    Leebo!
    from Yale OK
    Havent had as much time to work on it as hoped while I am in town this week, but got got the seat pans fitted.
  28. Leebo!
    Leebo!
    from Yale OK
    Got some time to get back on it. Got trunk floor/ tank area lined out
  29. Leebo!
    Leebo!
    from Yale OK
    Was getting ready to pull the body to finish the bottom side. Pushed her out in the sun, and really got to take in the side view from a distance. This shot has really got me motivated to keep pushing forward!
  30. Leebo!
    Leebo!
    from Yale OK
    Kim and I spent the whole weekend scraping and cleaning the bottom of the car. Spent many hours with a torch, scapers, and wire brush, but got it to an acceptable point where we could paint it with KBS Coating. Finished at 11:45 Sunday night, but was well worth the added effort.
