Projects How about a 53 Chevy Hardtop build !!??
Discussion in 'The Hokey Ass Message Board' started by Leebo!, Feb 4, 2013.
  1. ph8ed4life
    ph8ed4life
    from AZ
    Yep, that's the money shot there!
  2. Tin Can
    Tin Can
    Car looks great sittin out in the sun! That underside looks nice too
  3. vicksrods
    vicksrods
    great work ....subscibed.....even got the little lady out there workin i think you should keep her around...:D
  4. volksjunky
    volksjunky
    Damn ! subscribed .
  5. 4444Design
    4444Design
    cool project
    subscribed
  6. Cracker123
    Cracker123
    One of my favorite body styles. I love the way she sits!
  7. 54LedSled
    54LedSled
    Loving the looks of this ride, great work! Keep it up!
  8. tegam53
    tegam53
    Great looking work. Still trying to figure out how this forum works. Trying to subscribe, hope I did it right. Who did you purchase your floor pans from? I will be keeping up with your build. Need all the help I can get as I am trying to do as much of the work myself as I can. Thanks.
  9. Leebo!
    Leebo!
    from Yale OK
    Thanks teagam. My front pans are from national chevy. The rest I made patterns and made myself. Get pics of yours up, there is great advice here. Also, the are some good 49~ 54 owner group pages on Facebook that are a lot of help!
  10. redhawk74
    redhawk74
    nice work, looks great.... made the two link install look flawless.
  11. Leebo!
    Leebo!
    from Yale OK
    Thanks redhawk. Was actuly a pain in the ***. Will go with gambino 4 link on next thing I build. Actually dont save any money this way when you figure in cost of link, time spent on crossmember, panhard bar, new bushing and ubolts, cups to mount axle to link. I was happy I could push myself to make it work though. Hoping it rides nice!
  12. Hot Rod Chris
    Hot Rod Chris
    Daaaaaaaammmmmnnnnnn!!!!!!! That thing looks sick!!!!!!!
  13. Mr48chev
    Go to the top of the page, click on "thread tools, click on subscribe, then choose if you want notifications or not and subscribe.
    I just did as this looks to be one good build thread.
  14. Great build. I love 53-4 hardtops, and the '53 210 mdls are a fav of mine. The trailing arm crossmember, came out nice. Congrats!
  15. lawman
    lawman
    That's some nice work fellow !!!!
  16. bobafet1
    bobafet1
    Is the 69 camaro rear end a direct fit?
  17. zombi50
    zombi50
    from Madison WI
    Looks like fun. This makes me want to head out to the garage and get to work.
  18. mrconcdid
    mrconcdid
    from Florida
    Just found your thread, it is looking great. By all means keep the lady friend.
    You have done a great job on the build so far. keep at it.
    I have a trailing arm rear setup also, but havent pulled the trigger to put it in, was also planing on using the original crossmember. What rear are you using?
    Godspeed
    MrC.
  19. bobafet1
    bobafet1
    He mentioned he's using a 69 Camaro rear end earlier in the thread.
    I'm in the same boat and will be installing the trailing arm setup in my 53 hard top. I will also be bagging my car however I'm really trying to stay away from cutting into the body too much (trans tunnel/etc.). I was searching online and noticed someone used a two point driveshaft so that only the back 1/2 of the shaft would pivot thus eliminating the need for the tunnel. It looked like a nice setup and a good way to do it. Hopefully I can find that link again.
  20. Leebo!
    Leebo!
    from Yale OK
    mrconcdid-
    PM me before you do, there are some things that need to be taken into consideration before doing this project.
    Bobafet- I used a 69 camaro rear. Also had a 78 camaro rear. I think both of these coukld have been direct fit in a stock environment. I cut all brackets down to mount to the 2 links.
  21. James D
    James D
  22. hammered30
    hammered30
    from west aus
    The outside shot looks killer 53s look good in the weeds. keep up the great work.
    Cheers paul
  23. Crazy Legs
    Crazy Legs
    Looks great! Subscribing!!
  24. bobafet1
    bobafet1
    How are you going to route your exhaust?
    I've been looking at your setup and it seems like it may be difficult routing the exhaust past your rear axle. (too much stuff in the way)
    I was about to pull the trigger on a similar setup but then figured I would have clearance issues with the exhaust. Now I'm back to square one trying to figure out how to do this. Maybe mounting the bags on the trailing arm so they sit lower??
  25. i like your rear panhard bar, nice low roll center
    i thought i had it made in baging my 53 and made a crosmember and mounted the bags outboard and right where the exhaust goes
    gonna try to run the tailpipes under the rear and back up, got a wagon with the pipes under the rear and it works fine
    sure glad i got a exhaust bender my work is gonna be cut out for me, sure is nice welding and fabing but sometimes we are not engineers:eek:
  26. Leebo!
    Leebo!
    from Yale OK
    Exhaust will be run under the axle. I had that question at first, and a couple guys on here with similar setups recommended that solution.
  27. Crazy Legs
    Crazy Legs
    Leebo,
    How did you get the "car side" outer wheel well profile of the car to match the trailer fenders?
    And how did you attach the trailer fenders to the inside of the car wheel wells? (Seam sealer?, weld?, etc?)
  28. Leebo!
    Leebo!
    from Yale OK
    Crazy- just laid it down on a piece of 16ga and traced the radius. Used a hand shear to cut it out from there.
  29. Leebo!
    Leebo!
    from Yale OK
    Yeah, Im a little biased, but I think I will keep her around...she does good work, AND cleans up pretty nice!
  30. Smokey2
    Smokey2
    Leebo,
    Nah, No, No, Man !
    That ain't Her..................you'd NEVER get out in'
    garage !!!!!!!
    ___________________________________________________
    Good Build, an' the cars Nice also. :) :)
