Hot Rods How are these two plug welds?
Discussion in 'The Hokey Ass Message Board' started by old_chevy, Apr 18, 2025.
  1. old_chevy
    old_chevy
    from USA
    Just.dale likes this.
  2. Besides a bit blurry they look ok to me although I am not a certified welder. I just stick stuff together with the "hot glue gun".
    I'm not sure what you welded together I'm going to ***ume it's sheet metal and if that's the case it doesn't take much to get them to stick together a plug weld just needs to penetrate the bottom piece of metal and stick to the top piece of metal. If you plug welded something heavier I would look at the back side and you can kind of tell how good of penetration you got just by the color change on the back of the metal you welded into.
    Just Gary likes this.
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Can't tell from this side. Sometimes a plug weld will just fill the hole in if it does not penetrate to the other panel.
    rockable, Johnny Gee and Bentrodder like this.
  4. TA DAD
    TA DAD
    from NC
    I would say they are cold.
    Johnny Gee and Jeff34 like this.
  5. lostn51
    lostn51
    from Tennessee
    I’d have to see the backside to let you know if it’s good or not.
    rattlecanrods likes this.
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    Looks alittle cold but filling a sheet metal hole usually has to be alittle on the cold side.
    Yes show the back side. consider using a piece if br*** or copper as backing when welding a large hole.
    Okie Pete likes this.
  7. old_chevy
    old_chevy
    from USA
    Not able to see the backside here. Does the 360 ring around the spot weld indicate that weld did not go to the shoulder?
  8. alchemy
    alchemy
    Could be that the parent metal was just slightly melted at the edge of the bead, creating a very narrow dip. As everyone has said, after the bead is done, there’s no way to tell without looking at the HAZ on the back side.
  9. old_chevy
    old_chevy
    from USA
    Should these plug welds be grind down smooth or left in the current state?
  10. caprockfabshop
    caprockfabshop
    Where is this located on that car? Will it be body-worked before paint? Is it structural?
  11. old_chevy
    old_chevy
    from USA
    Rear quarter to door jam. Not sure what you mean by body work before paint. Please explain.
  12. caprockfabshop
    caprockfabshop
    You asked if that should be ground flush or left as is, so I mean is this area visible to the operator once the car is fully painted and ***embled? If so, then I'd recommend sanding flush to make it easier to prime and paint over later without showing a hump. If it's totally hidden, I'd leave as is and move on
    gimpyshotrods likes this.
  13. alchemy
    alchemy
    The strength in a (properly done) spot/plug weld is down between the two layers of steel. Anything that sticks up above the top layer is not adding any strength. Go ahead and grind it smooth.
  14. swade41
    swade41
    from Buffalo,NY
    This is the backside of my plug welds, which I'm fine with
    deathrowdave likes this.
  15. evintho
    evintho
    Here's some plug welds I did while grafting lengths of 2" x 3" rec steel together for my roadster frame. I overlapped the tubing and backed it with 3/16" plate then plug welded them. I plugged 'em hot!
  16. They taught us in the collision repair business to make a test panel or two of the same materuial you will be welding and then destructive test them
    This rings especially true, IMO, for a novice that isn't sure of the quality of their welds. I would recommend doing some test panels before welding on the car. You'll either find out you need more practice, or you're good to go, rather than hoping or guessing
    SS327 and lostone like this.
  17. lostone
    lostone
    from kansas
    Had to do this in a couple different GM and Chrysler cl***es to get certified for frame and structural repair. We'd weld small panels together then hook up chains and pull clamps with a pressure gauge and start pulling. We had to hit so many pounds of pressure before our welds broke or the metal ripped to p*** the cl***es and tests. We did plug welds and seam welds.
    SS327 likes this.
