Technical How can I fix this intake ?
Discussion in 'The Hokey Ass Message Board' started by swade41, Apr 15, 2021.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    You could get some gasket material & make your own intake gaskets with the unneeded ports blocked off .
    theHIGHLANDER and loudbang like this.
  2. swade41
    swade41
    from Buffalo,NY
    I have a few of these and was planning using them with gasket as long as the surface differences doesn't look to bad. On the chevys the little plate fits into the port where this will be flat across when filled.
    Seen this to late, I ordered the ''ALL CRAFTS' Professional Epoxy" this afternoon and another set of carbide bits for the Dremel tool to help clean it up.
    kidcampbell71 and loudbang like this.
  3. Pats55
    Pats55
    from NJ
    Okay I hope it works for you
    swade41, kidcampbell71 and loudbang like this.
  4. swade41
    swade41
    from Buffalo,NY
    Got it cleaned out and ready for epoxy
    Okie Pete, Deuces, loudbang and 5 others like this.
  5. Looks like dental work.....:)
    Deuces and loudbang like this.
  6. swade41
    swade41
    from Buffalo,NY
    I had a pick in there and that's all I could think about
    Nothing left to do but let it harden, sand it and see how it turned out.
    Okie Pete, saltflats, Deuces and 8 others like this.
  7. swade41
    swade41
    from Buffalo,NY
    Shining a light behind a straightedge it looks really close but should I be worried about those couple of divits ?
    My concern is the epoxy adhering to itself if I do try and fill them. I realize that they are not really in the gasket sealing area and pretty much wouldn't make a difference in function and you're not going to see it once the manifold is installed but it'd look better filled in ha ha ha
  8. squirrel
    looks good to me....
  9. Deuces
    Deuces
    Yep! Looks way better than it did...
    loudbang and swade41 like this.
  10. Black Panther
    Black Panther
    from SoCal
    Run it! I was wondering when I first saw this thread...why is he going through so much trouble for a throwaway intake? But fixing stuff because we can is where its at...and this repair might inspire other guys to fix theirs, instead of tossing an otherwise good part.....good job on the repair!
    Algoma56, loudbang, Deuces and 2 others like this.
  11. Scumdog
    Scumdog
    If it was my manifold I would check the front water runner area for signs of similar corrosion inside the runner area.
    Deuces likes this.
  12. swade41
    swade41
    from Buffalo,NY
    Looks great in there, oddly and weirdly those two spots are the only damage on the whole intake.
    Deuces, loudbang and Moriarity like this.
  13. I have an Edelbrock SBC intake that was just like it .
    The only places were just like yours,,,,,everywhere else was perfect
    swade41, Deuces and loudbang like this.
  14. ekimneirbo
    ekimneirbo
    If you decide to vapor blast it to clean the topside up, be sure to tell them not to clean that area.
    swade41, loudbang and Deuces like this.
  15. Dan Timberlake
    Dan Timberlake
    Probably not a real big deal, but I might have thought about an "aluminum" filled epoxy product, just to better match the manifold's thermal expansion.
  16. 56sedandelivery
    56sedandelivery
    Solid gaskets in that area, with some br*** shim stock, would be a smart move, at least I would think so anyways. Good luck with the repair work.
    I am Butch/56sedandelivery.
    swade41, Desoto291Hemi and Deuces like this.
  17. dumprat
    dumprat
    from b.c.
    We used to fix aluminum helicopter parts by burning out the corrosion with metal prep after a light blast. We then used a permatex product called metal set or something close to it. Smells like the old Deacon plastic steel. Machines pretty well and will glue in thread repair inserts to where you can torque parts to them.
  18. 1-SHOT
    1-SHOT
    from Denton
    You can also use anti cavitation additive to your radiator. We use in all our 7.3 diesel’s to prevent this. I have been using it on all my equipment.
    loudbang, swade41 and Deuces like this.
  19. Hollywood-East
    Hollywood-East
    You can re-epoxy if you scratch/put some tooth in the low spots... Same as doing mud/gl*** work...
  20. 1940Willys
    1940Willys
    Looks good to Me Phil. I'm sure you'll be fine.
    loudbang, Hollywood-East and Deuces like this.
