How can i mount a headlight like this one?
Discussion in 'The Hokey Ass Message Board' started by Johnny-B-Bad, Feb 2, 2007.
  1. Johnny-B-Bad
    Johnny-B-Bad
    Well i have headlights with an 'innie' mounting ball instead of the usual 'outtie'. So how can i go about mounting the light withount cutting and flipping to make it an 'outtie'?
    Thanks,
    John
  2. old beet
    old beet
    Looks like its missin the "outie" by the holes.......OLDBEET
  3. xderelict
    xderelict
    I used pool balls to mount mine.Drill them SLOWLY,they can explode,Ask me how I know that.
  4. swade41
    swade41
    from Buffalo,NY
    What are you mounting them to, frame or stands or ?
  5. budd
    budd
    got anymore pics of your car i`m doing a 28 chevy
  6. xderelict
    xderelict
    It's mounted on a modified model A? bar. The kind that would bolt to the fenders.I cut them off at the cups and welded the ends back on at a right angle so I could bolt it to the frame.[​IMG]
  7. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Yup, you are missing the outie part of the housing. Are those mopar? I have an extra set of buckets I might part with...EVILT
  8. Johnny-B-Bad
    Johnny-B-Bad
    This isnt the one im using.... just got this pic as an example. But that pool ball idea looks pretty cool.
  9. Roadsir
    Roadsir
  10. classicfins
    classicfins
  11. Squablow
    Squablow
    You could always salvage some mounts from a set of junk buckets and rivet them onto the bottoms of the buckets. I'm going to use Model A headlight mounts on the '36 Olds headlights that will hopefully one day go on my '26 T.
  12. alleyoop
    alleyoop
    Some tractor have that type,i have used lead powred in a latel this way you can make dif. size. alley
  13. mike budniewski
    mike budniewski
    would a couple of those cheap stamped 1 7/8 trailer hitch balls work? seems like they are always painted gray. i remember that they were hollow too
    Thanks,
    John[/quote]
  14. Take a peice of round mild steel rod equal to the diameter of the round indentation x about a foot long. Spend some serious grinder or lathe time and grind a spherical end on both ends of the the round bar that fits into the hole. Set the bar up in a ppower hacksaw and cut the ends off so that you end up with two "half spheres". Weld a bolt onto the half sheres, and weld the half shperes into the recess on the underside of the headlight pod.
  15. Frank
    Frank
    I have a pair of Chevrolet headlamps like that. They aren't mounted yet. I bought a couple of those chrome cone shaped escutcheons you would use on the wall around water lines under your kitchen sink. The I think I will have to use some crush sleeve inside because the escutcheon couldn't take much before it would crush trying to tighten the bolt. The large end covers the indention completely and the small end has a flat surface where the bolt comes out.
    Another possibility might be to use one of those small round topped caps you would use to cap off a post on a chainlink fence. I haven't looked into it close yet to see if its feasable. I think they are made of pot metal though.
  16. i used 2 bumper bolts from a big truck. i drilled and taped 3/8 holes in the round end and bolted them on my 32.it worked good for me.
    jim
  17. Johnny-B-Bad
    Johnny-B-Bad
    Thanks guys.... think i may use that post cap idea. That way i could weld it to my shock mounts.
    John
  18. SinisterCustom
    SinisterCustom
    I have a pair of Guides (I think) that have an even bigger divot....I may cut it out and reverse it.
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
    The military Dodge M37 built from '51 to '68 used a mount like that with the socket recessed into the headlight and a plate bracket bolted to the fender had the curve to fit into it.
    Possible source would be Vintage Power Wagon in Iowa.
    www.vintagepowerwagons.com
    Only reason it came to mind is that I restored an M37B1 about eight years ago.
