Technical how can I tell 348 from 409..
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 29, 2016.
  1. Paul
    Paul
    Editor
    And low deck from tall? Engine is in an early 60's 1/2 ton pickup.
  2. Budget36
    Budget36
  3. falcongeorge
    falcongeorge
    from BC
    think they were all the same deck height. Are you thinking of 366/427 rat motors from bigger trucks?
  4. belair
    belair
    409 dipstick on p*** side.
    Perfectly Flaw'd likes this.
  5. Paul
    Paul
    Editor
    After a little more research it would appear that aside from internal inspection, decyphering the casting numbers at back of the block is the best bet.
    Right now all I have to go by a couple small grainy pictures.
    I see what looks like a cast iron intake with four barrel and dip stick on driver side.
    Truck has 4 speed transmission, looks relatively clean and is said to run and drive very good.
    But priced too high to fit description unless the engine was something special.
  6. The truck 348 had the dipstick on the p***enger side. the best most certain way is to pull the heads and measure it.
    56don likes this.
  7. pg409
    pg409
    Suggest go to the 348-409.com forum.
    There is a lot of information on there
  8. timwhit
    timwhit
    Actuate the loud pedal?
    stillrunners likes this.
  9. 56don
    56don
    Some of the truck engines had two relief cuts in the block and that to me would preclude using it for a hot rod because of the excessively low compression. You need to pull a head to be certain.
    falcongeorge likes this.
  10. pg409
    pg409
    Ross make pistons to compensate for truck engines low compression.
    RileyRacing likes this.
  11. donsz
    donsz
  12. 59Apachegail
    59Apachegail
    from New York
    Can't use the dipstick idea because the 348 and 409 oil pans interchanged. Use the 348 site link and there is a section to plug in your casting code..
  13. cavman
    cavman
    Crankshaft flywheel flange is round on a 348, bell shaped on 409.
  14. Paul
    Paul
    Editor
    thanks for all the tips guys,
    I will try to get a first hand look at it in the next day or two,
    if it doesn't sell before then,
    and get some numbers off it.
    ...wonder if one of those fancy new fangled inspection cameras run down a plug hole would show if the bores had the low compression over-cut?..
  15. ROADSTER1927
    ROADSTER1927
    The extra cut in the cylinder is an advantage with the right pistons, it unshroudes the exhaust vale for more performance! Gary
    bobwop and saltflats like this.
  16. Gene Boul
    Gene Boul
    Been awhile had several of each but back in the 60's. Besides the dipstick I seem to remember that the intake bolts are "in-line" in 348's but center ones are staggered in 409's.
  17. Larry T
    Larry T
    No, a standard performance 409 intake and a 348 intake will interchange.
    And the dipstick is in the oil pan and a 409 oilpan will bolt onto a 348.
    Only way I know to check externally is to look at the stamping on the front right hand side of the engine, or the casting numbers on the rear of the engine.
  18. Bandit Billy
    Bandit Billy
    I need to make it clear that I am no expert on the subject but according to another thread on the 409 at the moment, the 348 has a bow rope attached and the 409 utilized an anchor chain. Hey, I don't make this stuff up, I just report it.
    Old wolf and hotroddon like this.
  19. DDDenny
    Carefull Billy
    You have ventured into "choppy" waters!
  20. ROADSTER1927
    ROADSTER1927
    YAH What He said! :DGary
  21. dorf
    dorf
    from ohio
    so is 348 truck engines
  22. keith27T
    keith27T
    Are the water pumps the same?
    :rolleyes:
  23. stillrunners
    stillrunners
    from dallas
    look for the "X" below the left'driver's side head....most 61/62's 409's didn't 409 a.jpg 409 a.jpg have them...
  24. cavman
    cavman
    The water pumps are the same, and they started putting the X's on the blocks in late '62. It is a pretty good indicator that it may be '09, but not foolproof, as some 348" truck blocks had them also.
  25. pg409
    pg409
    The "X" on the block also denotes a p***enger car engine.
  26. cavman
    cavman
    The "X" on the block was also put on truck blocks. I have one. Here is one other way to tell if you have a truck block, but only good for this one year.
    For the 1965 #3857656 block, look on the lower front of block on each side of the timing cover. On the left side (right side when standing in front of engine) there are two 7/16" co**** thread bolt holes which the power steering pump bolts to. These are drilled on all blocks both car and trucks however, truck blocks will also have these drilled and tapped on the right side of the block (left side when standing in front of engine) where p***enger car blocks won't. No bolt holes on that side indicates a car block, with bolt holes indicates a truck block. No car blocks ever came from the factory with these drilled. Note however, someone other than the factory could drill and tap these so it's not proof positive.
