Projects How can I tell if i got solid or hydraulic lifters in my 402 bbc
Discussion in 'The Hokey Ass Message Board' started by timmy2times, Apr 20, 2014.
  1. Ebbsspeed
    Ebbsspeed
    True, I could have been more specific, but I didn't know if the clearance was one ten thousandth or two ten thousandths, so I said "mere ten thousandths". Tight, but still able to slide.
    The decimal representation of one tenth is 0.1.
    Hnstray likes this.
  2. I killed the 1st motor because of a power valve in my carb when i had the carb rebuilt they threw in a normal power valve. I was running a comp 280h cam it was hydraulic lifters and it was fine. With the normal powervalve when i would tune it it would be ritch but when i got on it it would lean. I was stop light racing a new camaro and it backfired and made piston #3 disapear with the intake valve hahaha. 6 months later got a junk yard 454 it was a burnout monster hit the oilpan on my drive way incline. Lustened to a lame famous words its fine. Run it well the oil pickup broke and i spun a bearing going to the corner store
    Now have a lil 87 corvette mouse seems to be fine my 750 speed demon carb is too big though so its kinda bogging im currently waiting on a rebuild kit for a 650 holley i have in the garage i know im not as savy as you old schoolers out here but hey im having fun and i havr less than 5k total cost for everything ive ran. I just listen and try and pickup all you folks info and try to remember a lil bit as i go on my quest to kill tires and go fast. All in all no one else gonna build it weld it or fix it but me
    Sent from my LGMS330 using H.A.M.B. mobile app
