How can it be done?
Discussion in 'The Hokey Ass Message Board' started by mcgurk302, Jan 4, 2008.
  1. mcgurk302
    mcgurk302
    from Orem, Utah
    So guys, is it possible to lift my front end without the solid axle conversion? If you've seen a g***er/drag car on stiltz without the solid axle...please chime in. Thanks
  2. chaddilac
    chaddilac
    You can reverse Z the frame and make longer motor mounts.... wouldn't look very good with A arms pushed way down under the frame though.
  3. GassersGarage
    GassersGarage
    Sure. If you have A arms, they make an upper ball joint spacer, then you add stiffer springs. Cheap way is to use spring spacers. You can also use raised spindles which are made for pre-runner type truck, S-10's, Rangers, etc.....
  4. What CAR???????????
  5. mcgurk302
    mcgurk302
    from Orem, Utah
    The car is a '54 olds. Fairly close to other GM's I would think?
  6. Gearhd69
    Gearhd69
    On a 49 to 54 Chevy you can put spacers between the crossmember and the frame to raise the frontend.
    But I heard that the Olds frontends where different.
    If they are the same as the Chevys that could be an option.
  7. HMMMM, no balljoints? Kingpin deal? I'd have to see it
  8. low budget
    low budget
    from Central Ky
    I know this is a older post but do you have anymore info on these raised spindles you are talking about?
    I want the front of my 55 to set high.
    It had a set of the c type spacers in it but the guy I got it from took one out and lost it and never got to the other side, so now I only have one:(
  9. Side
    Side
    Those C type spacers are available from super lift. Not for your car of course. You will have to figure out which ones you need yourself.
  10. I think g***er is right. Some lifting spindles would be an easy fix. I bet an off road shop could fab up a pair.
